zed1
Cup holder for a 520
 I found this example. Any other designs you found?
22B35B37-8403-49E7-8EEE-FB9E59FAAAF1
  • Like 3
Share this post
Link to post
That is a great find!  Please paint to match your beautiful 520!
Share this post
Link to post
I only have the photo...someone with better fabricating skills may want to make this and offer to others!!! I'd be the first one to buy it!
Hint, hint.
Keith
Share this post
Link to post
The base would be easy to bend then fabricate the top.  I will ask my brother Garret if he would be interasted pn making some of these for sale.  I can not use my 520 for a pattern because of the custom tunnel.  But I do have a 71 521 cab the I believe has a virgin tunnel.  I will let you know what he says.
Share this post
Link to post
I just emailed my brother Garret the picture from your post above.  I will be over at his house later today.  He ahs a broken foot and I am helping him out by doing yard work for him to keep the city of phoenix of his back.
Share this post
Link to post
Charlie,
As a reminder, the early 520's have the shifter rod hole located closer to the firewall to accommodate the early transmission design.  The distance between the heater box and the shifter boot is 9.5".
Since the later transmission design moved the shifter boot closer to the seat, the previously referenced distance is greater.
Thanks to you and Garret for your assistance on this project.
Keith
Share this post
Link to post
You are welcome.  If you can get some dimminsions from your truck it sould help.  The 521 shifter is closer to the seat as mentioned
Share this post
Link to post
Holy Sheep Shit....I had one exactly like that in my 510 wagon in the late 1980's. The tension in the metal held it to the transmission hump.
Share this post
Link to post
Been meaning to fab something up like this for a while for both my 620 and my 510... just havent had the metal around...
Stealing a idea from the lonely driver company - who makes nice looking aluminum ones - I had a wheel spacer lying around and threw this together in 5 minutes. Not sure what the seat mounts are like in the 520, but another idea. Sliced some fuel line open to line the inside of the spacer to make the diameter a little smaller.
20200407_160217
  • Like 4
Share this post
Link to post
