Draker Posted August 2, 2020 Report Share Posted August 2, 2020 Should be just fine without them. Quote Link to comment
510revisited Posted August 2, 2020 Author Report Share Posted August 2, 2020 Ok, how to start this.... from the top. I bench bled the master, and during the process flyid would squirt out past the little plastic plugs during the process, which i had a feeling would happen. Did my best to get all the air out. Bled the system a few times,to help aid in getting all the old stuff out, and new stuff in. Found one of my rubber lines in the rear was leaking so i replaced it and proceeded to bleed the entire system again this morning. Heres my question. When bleeding i watch the tube hooked to the bleeder valve and see no air coming out, on all four corners. But the pedal still seems a bit soft. I suspect the master has air in it. Do i need to remove the master and bench bleed again, or should just switch to vacuum bleeding? With a 7/8 z master, and zx disc's up front should the pedal be nice and firm, or is it gonna be a bit spongy. I have NO brake booster. Admittedly ive never had the most patience for bleeding brakes. But i understand the process, and the idea behind it.. Any and all is appreciated Quote Link to comment
