Chavez88 Posted April 5, 2020 Report Share Posted April 5, 2020 trying to upgrade cam on my Z24 engine i was told that a cam from a nissan 240 will fit . what cams do you guys recommend instead of buying new ones . Quote Link to comment
datzenmike Posted April 5, 2020 Report Share Posted April 5, 2020 No. Two totally different engines. The KA24E single cam has 3 lobes on it per cylinder. Not even close. I myself wouldn't bother as the head is very poor design for adding any extra performance to it. Simply put, it doesn't breath well because the intake and exhaust ports are so low on the sides that they have to make a sharp bend to enter the combustion chamber . If too much lift is added the valves will hit each other so no cam maker will have much lift added. I've seen a few after market cams and there are almost the same specs as the stock one. Do you have emissions testing? If not I would get a 38/38 Weber and pull the stock muffler off and put a turbo style on. NOT a fart cannon a turbo style. Quote Link to comment
banzai510(hainz) Posted April 6, 2020 Report Share Posted April 6, 2020 Chavez if your truck is running fine just keep it that way. Quote Link to comment
Chavez88 Posted April 7, 2020 Author Report Share Posted April 7, 2020 cool guys thanks.. ill just keep it the way it is right now, Quote Link to comment
