Theballinstallin Posted March 28, 2020 Report Share Posted March 28, 2020 I am currently trying to order new pistons and connecting rods for my l20b engine but i am having the hardest time trying to find any any that fit or that look like they be close. If somebody is willing to point me to a website/parts that work or the specs i need i appericate it 1 Quote Link to comment
datzenmike Posted March 28, 2020 Report Share Posted March 28, 2020 Con rods don't wear out in regular use and they are reusable. Are you looking for an over size piston and having the block bored? Should be able to find after market over size ones. Have to ask... what's wrong with the ones you have?? 1 1 Quote Link to comment
Theballinstallin Posted March 28, 2020 Author Report Share Posted March 28, 2020 i have the orignal engine that the rod end have hammer marks on it cause they were rusted into place but i bought a engine from my local savage yard the connecting rods are good but i only have 3 connecting rods the other one is still stuck in the spare block 1 Quote Link to comment
Theballinstallin Posted March 28, 2020 Author Report Share Posted March 28, 2020 i was gonna find one to send a picture of but ive lost them but they had very deep groves on the bearing surface 1 Quote Link to comment
datzenmike Posted March 28, 2020 Report Share Posted March 28, 2020 What's stopping you getting the spare one out with the other three already out of the way? Unbolt the big end from the crank and slip a bar down past it to the under side of the piston and pound it out. Probably will loose the piston but you will have the rod. Then get a set of oversize pistons for the rods and bore one of those blocks to the oversize. You would never pound metal on metal on the rod ends to drive them out of the block. Better to bash on the piston bottoms. Or place a block of wood over the ends to protect them. 1 Quote Link to comment
Theballinstallin Posted March 28, 2020 Author Report Share Posted March 28, 2020 how did i not think of that. ive been overthinking this well i apperciate the help 1 Quote Link to comment
datzenmike Posted March 28, 2020 Report Share Posted March 28, 2020 Connecting rods from a Z22 engine in the 720 truck are also the same as the L20B. Just in case you have one. 1 Quote Link to comment
Theballinstallin Posted March 28, 2020 Author Report Share Posted March 28, 2020 i do not but do the pistons from a z22 fit in a l20b im assuming not but im curious 1 Quote Link to comment
420n620 Posted March 28, 2020 Report Share Posted March 28, 2020 got L20 rods/pistons in my ad. Buy 1 or 2 or all 3. Just let me know through the ad, not from this post. Send zip code will be helpful also. 1 Quote Link to comment
datzenmike Posted March 28, 2020 Report Share Posted March 28, 2020 40 minutes ago, Theballinstallin said: i do not but do the pistons from a z22 fit in a l20b im assuming not but im curious No. The piston pin height is such that the piston top would stick up out of the block hitting the underside of the head. In addition they are 2mm wider diameter. You could over bore the L20B block from 85mm to 87mm and put Z22 pistons and crankshaft in. This would now make a 2.2liter L20B. AKAa 'stroker' L20B 1 Quote Link to comment
Theballinstallin Posted March 28, 2020 Author Report Share Posted March 28, 2020 the crankshafts journels are the same size 1 Quote Link to comment
Theballinstallin Posted April 12, 2020 Author Report Share Posted April 12, 2020 On 3/28/2020 at 11:30 AM, datzenmike said: On 3/27/2020 at 10:00 PM, datzenmike said: Con rods don't wear out in regular use and they are reusable. Are you looking for an over size piston and having the block bored? Should be able to find after market over size ones. Have to ask... what's wrong with the ones you have?? maybe a dumb question but are you able to re use the wrist pin or would i need to buy new ones 1 Quote Link to comment
datzenmike Posted April 12, 2020 Report Share Posted April 12, 2020 Pins are totally re-usable. They are a slip fit in the piston but press fit through the rod small end. I pressed some out of L20B pistons and was 1,200-1,500 PSI hydraulic pressure. 1 Quote Link to comment
john510 Posted April 12, 2020 Report Share Posted April 12, 2020 New pistons should come with wrist pins.I would not re use a wrist pin unless in a bind. 1 Quote Link to comment
datzenmike Posted April 12, 2020 Report Share Posted April 12, 2020 I should have said reusable on the original pistons. 2 Quote Link to comment
