Stoffregen Motorsports Posted April 12, 2020 Report Share Posted April 12, 2020 I have had to drive them off before with a hammer and a large punch. If I recall, there are two sections in the backing plate that you can fit a drift into to hit the drums off from the back side. Again, heat the center of the drum, between the lug nuts and spray the section around the axle shaft with WD40 or similar. The cooling of the metal will suck in the lubricant. Heat again just prior to removal. If you can back off the brake adjusters, that will help too. Quote Link to comment
Rusty Dawg Posted April 12, 2020 Author Report Share Posted April 12, 2020 Thanks for the suggestions Stoffregen. I've already backed off the brakes and tried heat, but nothing. I did spray BP on the axle last night to let it soak. I will spray more today and I'll try to punch it out while applying heat tomorrow. I was wondering if the key that is in there needs to come out first, although I don't know how I would do so. It seems to just be in there as a guide. The front brakes did not have a key. 1 Quote Link to comment
Charlie69 Posted April 12, 2020 Report Share Posted April 12, 2020 Heat up the drum and the spray with penetrating lube the heat will suck it in better than if applied cold. becareful as most penetrating lubes are flammable. Quote Link to comment
Rusty Dawg Posted April 13, 2020 Author Report Share Posted April 13, 2020 Will do Charlie69 1 Quote Link to comment
wayno Posted April 14, 2020 Report Share Posted April 14, 2020 I had a trick for getting the drums off my 521, I had a bar bell shaft that was just over 6' long, I would remove the wheels, place the bar bell shaft on top of the leaf springs(rear), I would put the end of the shaft on the back edge of the drum I wanted off and I would then go to the other side and hit the end of the shaft with a sledge. Remember that there are 2 Phillips head screws holding them early drums on the axle ends, you have to take them out. 1 Quote Link to comment
Rusty Dawg Posted April 14, 2020 Author Report Share Posted April 14, 2020 Wait, there are two screws holding the drums on the axles? You're kidding me, right? 1 Quote Link to comment
Rusty Dawg Posted April 14, 2020 Author Report Share Posted April 14, 2020 All I see is like an "escape hatch" but not screws. Where does that lid lead to? 1 Quote Link to comment
wayno Posted April 14, 2020 Report Share Posted April 14, 2020 (edited) OK, these are the drums on my 1963 Datsun 320 which is really a 1962 sold in 1963, you can see where the 2 screws are missing on my drum. Edited April 14, 2020 by wayno 1 Quote Link to comment
mklotz70 Posted April 14, 2020 Report Share Posted April 14, 2020 If you have replacement drums already, between the 3 and 6 min marks on this vid, there's a drastic, last resort way you can try. 1 Quote Link to comment
jagman Posted April 14, 2020 Report Share Posted April 14, 2020 The screws on the drums are called grub screws in british parlance. They were put in to keep the drum in place in the event your studs broke and you lost the wheel. I soak the axle and the stud openings with pb blaster an then use a brass drift and 5 pound hammer on the outer edge of the drum to break them loose. I usually turn the drum as I do this. It may take some patience. When removed cleanup the axle and stud openings before you remount the drum to make the next time easier. My jags and the Riley are built this way. 1 Quote Link to comment
Rusty Dawg Posted April 14, 2020 Author Report Share Posted April 14, 2020 Nothing here sirs... 1 Quote Link to comment
MikeRL411 Posted April 14, 2020 Report Share Posted April 14, 2020 18 minutes ago, Rusty Dawg said: Nothing here sirs... You have a Woodruff key on the axel shaft. Try penetrating oil on that. rust just may be contributing to the "sticktion". A last resort would be to find the world's largest 3 point gear puller, attach it to 3 equally spaced points on the rim, put the central shaft on the axel and crank away. You will either crack the drum, warp the drum, or pull the drum off. 1 Quote Link to comment
Rusty Dawg Posted April 14, 2020 Author Report Share Posted April 14, 2020 I've been soaking it for 3 days and I will go at it again today. I would assume that heat would help as well. Thanks for the input MikeRL411. 1 Quote Link to comment
mklotz70 Posted April 14, 2020 Report Share Posted April 14, 2020 Geez.....you should have just led with that picture! Go to a parts store that will rent/loan gear/hub pullers. Get the biggest one you can. When you have a lot of tension on it, then try the heat and hammer. 2 Quote Link to comment
Stoffregen Motorsports Posted April 14, 2020 Report Share Posted April 14, 2020 Yeah, I didn't realize that it was a two piece shaft with a woodruff key. Still, heat will be your friend and you may need to use a lot. Here's a trick, if you get the metal hot and fail to remove it while it's hot, give up and walk away. Why? Because the heat applied eventually soaks into the shaft and grows that too, negating any benefits from heating. So, heat until smoking, but not until it starts to change the color of the metal, try removal probably with a puller on this setup. If a few minutes go by without success, try again after it cools. Quote Link to comment
Rusty Dawg Posted April 14, 2020 Author Report Share Posted April 14, 2020 Sorry for not posting a photo. I did mention the key in a previous post and since no one mentioned anything, I didn't think anything of it. I just thought the key was a guide. I will take your suggestions and give it a whirl. Quote Link to comment
Rusty Dawg Posted April 15, 2020 Author Report Share Posted April 15, 2020 Tried a puller and this is all I got.....bahahahhahaha! Once cool, I'll try heat once again. The video of the dude cutting the drum might not be too far off. Quote Link to comment
gene knight Posted April 15, 2020 Report Share Posted April 15, 2020 truck looks like a 320 Quote Link to comment
320 Newb Posted April 15, 2020 Report Share Posted April 15, 2020 Watch those toes! Quote Link to comment
Rusty Dawg Posted April 15, 2020 Author Report Share Posted April 15, 2020 Hard not to wear sandals in sunny California😎 Quote Link to comment
Rusty Dawg Posted April 16, 2020 Author Report Share Posted April 16, 2020 (edited) Can anyone tell me what this lid leads to? I am hoping there's an eject button in it and the drum falls off.😬 Edited April 16, 2020 by Rusty Dawg Quote Link to comment
Ooph! Posted April 16, 2020 Report Share Posted April 16, 2020 (edited) The hole on the upper left of the picture appears to be the adjuster nut, you will need to adjust it so the brake shoes clear the drum and the drum moves freely. I'm not sure what the other hole is for. Edited April 16, 2020 by Ooph! Quote Link to comment
Rusty Dawg Posted April 16, 2020 Author Report Share Posted April 16, 2020 Ya, I'm trying to figure out what the other one is for. It's a lid that you can open and close, but it's one piece and I think after opening and closing it several times, it will simply bust off. Quote Link to comment
wayno Posted April 16, 2020 Report Share Posted April 16, 2020 It still is not off, it appears to be close, just keep tapping away at it, eventually it will come off. I wonder if this truck has the 513 rear gears I have heard of(I think it was 513) Quote Link to comment
Rusty Dawg Posted April 16, 2020 Author Report Share Posted April 16, 2020 How do you verify what gears the rear end has? Would I have to remove the pumpkin? Would it be a foul to push the key inwards on the drum/axle? Quote Link to comment
