carterb Posted March 23, 2020 Report Share Posted March 23, 2020 I am in the process of switching the intake and exhaust in my '78 620 from the stock downdraft carb with heavily integrated intake/exhaust manifold with single downpipe to a 510 dual SU set-up with the 510 4 into 2 exhaust manifold and 2 into 1 Y-pipe. The problem is that the Y-pipe runs into the torsion bar. Did earlier 620 trucks come with the 4-2-1 type exhaust system? Is the exhaust manifold the same as on the 510? What does the Y-pipe look like? Anyone have a spare I can purchase? It looks like the 510 Y-pipe would work if I could twist it to fit between the torsion bar and frame rail, but as-is, there is no way it will fit. Quote Link to comment
banzai510(hainz) Posted March 23, 2020 Report Share Posted March 23, 2020 (edited) Im thinking the early L16/18 yes then the late L20 had 2 types I know of. HOWABOUT a 521 y pipe. The exhaust manifolds are pretty much the same on 510/521 that I seen of. beside air injection or not. here is where I think people were using the Common sold Trimill short tube header and making a way around the the torsion bar Edited March 23, 2020 by banzai510(hainz) Quote Link to comment
DanielC Posted March 23, 2020 Report Share Posted March 23, 2020 This is a thread on how I made the exhaust system on my 521 trucks. They pretty much have the same exhaust pipe clearance issues. https://ratsun.net/topic/61167-how-i-replaced-a-521-exhaust-system/ Quote Link to comment
Stoffregen Motorsports Posted March 23, 2020 Report Share Posted March 23, 2020 56 minutes ago, carterb said: It looks like the 510 Y-pipe would work if I could twist it to fit between the torsion bar and frame rail, but as-is, there is no way it will fit. Can you weld? Buy some mandrel bends and make it fit. https://www.summitracing.com/search/part-type/exhaust-tubing/exhaust-tubing-type/bend/tubing-material/steel?N=tubing-material%3Asteel&SortBy=Default&SortOrder=Ascending&ibanner=SREPD4 Quote Link to comment
datzenmike Posted March 23, 2020 Report Share Posted March 23, 2020 Only the '75 through '77 had the integrated intake and exhaust on the U67 head. The '78-'80 with W58 were separate. Maybe your engine was swapped. The '73 and '74 has L16 and L18 engines with the 4 onto 2 exhaust. All L20B were 4 into one manifolds. 1 Quote Link to comment
carterb Posted March 24, 2020 Author Report Share Posted March 24, 2020 Thanks. I know the bolted together integrated intake/exhaust you are talking about. The L20 stuff isn't quite that bad but it's still pretty much a unit with the metal connection tube and all the other associated garbage. I found what must be a 521 collector? But even that has some fitment issues. It hits the transmission. I think it may have a larger than stock exhaust pipe welded to it and that plus the weld is creating the interference. More here: 1 Quote Link to comment
datzenmike Posted March 24, 2020 Report Share Posted March 24, 2020 I have the U67 head with the co joined manifolds. I took them off and put an earlier L16 4 into 2 manifold on. I had an L16 exhaust flange and surprisingly a 240sx dual down pipe is pretty close and as the 71B and 71C are physically similar transmissions, it fits around it quite well. I narrowed the 2 pipes to 1.5" so they would fit up into the L16 manifold and welded them in place End result was almost the same as a long tube header... The intake was useless with that big hole in it. So used a later '79 intake and drilled out the U67 head so it had coolant passages for the manifold. To make it look like an earlier intake I took the EGR manifold off and with some grinding an tapping and some JB weld... This to this. 1 Quote Link to comment
