San segrest Posted March 11, 2020 Report Share Posted March 11, 2020 I want to change the wheel cylinder bore size from 13/ 16 to 3/4 do i have to change to a different master cylinder. Can it be done. Help some body. 1 Quote Link to comment
datzenmike Posted March 11, 2020 Report Share Posted March 11, 2020 Not necessarily. A larger wheel cylinder will need more fluid moved to get the same pressure and stopping performance. Your master can easily enough do that, but it will have to travel farther towards the floor. The amount??? probably not much but it may seem sort of mushy after, just be aware of that. 1 Quote Link to comment
mklotz70 Posted March 11, 2020 Report Share Posted March 11, 2020 I agree with Mike. Also.....along with more pedal travel, it should require less leg effort because it creates the effect of more leverage.....which is why it can feel "mushy" as Mike stated. As Mike pointed out, the wheel cyls will require more fluid.....for just one wheel cyl, pretty insignificant, but if you're changing all 4, it could be a substantial change. Basically, you'll have to change all 4, or at least both fronts or both backs. Assuming you're still trying to use the stock m/c, you'll have to change all 4. You'll also need to make sure that your drums and shoes are in great shape and adjusted perfectly. Any extra travel from mis-adjustment could require too much pedal travel and be unsafe. 1 Quote Link to comment
Crashtd420 Posted March 11, 2020 Report Share Posted March 11, 2020 Umm... Isnt 13/16 (.8125) Bigger than 3/4 (.750) So he reducing the diameter not increasing.... 2 Quote Link to comment
mklotz70 Posted March 11, 2020 Report Share Posted March 11, 2020 4 minutes ago, Crashtd420 said: Umm... Isnt 13/16 (.8125) Bigger than 3/4 (.750) So he reducing the diameter not increasing.... DOH!!! Okay....pretty much the opposite then. Downsizing the wheel cyls shouldn't cause much of an issue.....just more leg effort. Thanks Crash. :) 1 Quote Link to comment
banzai510(hainz) Posted March 11, 2020 Report Share Posted March 11, 2020 (edited) I have a wheel cylinder that different and its minute amount of difference if that and would worry about it as it needed it right now and installed it. Just adjust the shoes and youll be fine 13 /16 3/4 = 12/16 not much to worry about just make sure its for a 521 as they are SAE threads I believe on a lot of stuff .. I don't mix up with 620 stuff as I assume they all metric Edited March 11, 2020 by banzai510(hainz) 1 Quote Link to comment
Stoffregen Motorsports Posted March 11, 2020 Report Share Posted March 11, 2020 43 minutes ago, banzai510(hainz) said: I have a wheel cylinder that different and its minute amount of difference if that and would worry about it as it needed it right now and installed it. Just adjust the shoes and youll be fine 13 /16 3/4 = 12/16 not much to worry about just make sure its for a 521 as they are SAE threads I believe on a lot of stuff .. I don't mix up with 620 stuff as I assume they all metric You can swap from SAE to metric. You just need metric banjo bolts and metric bolts for where it mounts to the backing plate. 2 Quote Link to comment
datzenmike Posted March 11, 2020 Report Share Posted March 11, 2020 Was only on my first coffee this morning. As soon as I read the title just now I could see the glaring mistake. OK.... Going to a smaller wheel cylinders will require less fluid so the pedal will not need to travel as far. It may feel stiffer. 1 Quote Link to comment
DanielC Posted March 12, 2020 Report Share Posted March 12, 2020 Going from 13/16 to 3/4 wheel cylinders in the rear will also slightly reduce the tendency of the rear wheels to lock up under hard braking. If you rarely haul anything in your 521 this may be a good thing. I have seen both 3/4 and 13/16 wheel cylinders, and I also have seen wheel cylinders marked wrong, I.E. a cylinder marked 13/16 that was actually 3/4 or the other way around. 2 1 Quote Link to comment
