Wy720 Posted March 4, 2020 Report Share Posted March 4, 2020 How’s it going I recently got a 81’ 720 4wd . guy I got it from put a flatbed on it , has sat on his ranch for several years I got it home . Truck has no tail lights , brake lights . Signals, heater . Anything ... headlights work on and off , it doesn’t seem to be a wiring nightmare but any input on this and what It could be would be really appreciated. Also if anyone has a picture of the fuse block inside the cab I would greatly appreciate it . Mine is labeled with number 1- so on . But doesn’t list what fuse is what . If anyone know which fuse controls what Quote Link to comment
datzenmike Posted March 5, 2020 Report Share Posted March 5, 2020 1 ignition coil exhaust side 2 ignition coil intake side, fuel pump auto choke, idle cut 3 rear window defog if equipped 4 fuel and temp gauge, tach, turn signal, bak up lights, 5 6 wipers, air con 7 radio, cigar lighter 8 clock 9 10 blower motor 11 horn 12 brake and 4 way hazard lights 13 tail, licence, marker and interior lights 14 LH headlights 15 RH headlights Quote Link to comment
