Sr20det cam caps
Jalj47
I removed the head of my s13 sr20 to replace the timing chain, my dad later moved my cam caps from where I had them and they were put out of order. I was wondering if it’s is a big problem and if anyone knows the order they should be.
(I know the ones that go on the intake side and the exhaust side just not which one goes where)
  • Replies 1
its kinda a problem. usually if they have the caps in the wrong place the cam wont turn...
soo.... put your cams in with no rockers, do your front and rear caps first as I think they are thicker than the rest, arrows pointing towards the gears.
torque one cap down at a time and spin the cam after each cam cap is installed. if it starts binding up try it somewhere else. you should be able to turn the cam with your fingers when its all torqued with no rockers installed.
once you go through that process NUMBER THEM so you dont have to do it again 🙂
