510 Headlight Relay
JerryP43
Hey All, trying to find a headlight relay for a 72 510 6 pin relay or a good work around.  Only number I can come up with so far is 25230-N0200 which seems to not exist out there in the wild. Any help would be appreciated.
  • Replies 4
Replace with newer style Bosch , it looks kinda complicated but , it's easy .. You can buy pigtail and relay at most automotive parts stores.
Link to a thread about it with wiring diagram that i think used,, copy diagram and have it underhood ,, easy peasy ,, there are a few other threads about it  out there if you googly googly
http://the510realm.com/viewtopic.php?f=2&t=8226
Relay is a bit melted, we bypassed and soldered a wire onto relay and got lights working but the fear is that the solder joint might fail if it gets hot enough, granted that should not happen but is a possibility.
