thisismatt Posted August 2, 2020 Report Share Posted August 2, 2020 16 minutes ago, john510 said: I had spine surgery with a 1 1/2" incision that was glued together,no stitches.The incision never bled or oozed anything.Also can hardly see the scar. Me too Quote Link to comment
a.d._510_n_ok Posted August 2, 2020 Report Share Posted August 2, 2020 DC Mayor Exempts John Lewis Funeral Attendees From City’s Quarantine Restrictions https://www.dailywire.com/news/dc-mayor-exempts-john-lewis-funeral-attendees-from-citys-quarantine-restrictions?%3Futm_source=twitter&utm_medium=social&utm_campaign=dwtwitter&fbclid=IwAR2gA14s_Pk6_xIjACrfhy-BjkSmteGY4oJMz1sfkOCDSqqOvpUHFle6zp8 Quote Link to comment
john510 Posted August 2, 2020 Report Share Posted August 2, 2020 No problem,only Republicans get Covid.Most everybody there should be fine. 2 2 Quote Link to comment
grannyknot Posted August 2, 2020 Report Share Posted August 2, 2020 1 hour ago, john510 said: No problem,only Republicans get Covid.Most everybody there should be fine. That would be interesting to see how it breaks down between the Dems and Reps. Quote Link to comment
john510 Posted August 2, 2020 Report Share Posted August 2, 2020 1 hour ago, grannyknot said: That would be interesting to see how it breaks down between the Dems and Reps. Considering it's John Lewis i'd bet it's pretty one sided. Quote Link to comment
grannyknot Posted August 3, 2020 Report Share Posted August 3, 2020 1 hour ago, john510 said: Considering it's John Lewis i'd bet it's pretty one sided. I was thinking the how the split would look in regards to Covid19, getting accurate numbers would be difficult and which ever way it fell it would be accompanied by several halfwit theories on who is to blame. Quote Link to comment
thisismatt Posted August 3, 2020 Report Share Posted August 3, 2020 1 hour ago, grannyknot said: I was thinking the how the split would look in regards to Covid19, getting accurate numbers would be difficult and which ever way it fell it would be accompanied by several halfwit theories on who is to blame. No theories needed, it's a foregone conclusion. Trump is to blame. 7 Quote Link to comment
Chuck Most Posted August 12, 2020 Report Share Posted August 12, 2020 Also my back window is fucked up. 1 Quote Link to comment
thisismatt Posted August 12, 2020 Report Share Posted August 12, 2020 6 minutes ago, Chuck Most said: Also my back window is fucked up. Probably got rear ended. Hence the aids 3 1 Quote Link to comment
Chuck Most Posted August 12, 2020 Report Share Posted August 12, 2020 2 hours ago, thisismatt said: Probably got rear ended. Hence the aids Brilliant deduction Sir. 1 Quote Link to comment
datzenmike Posted August 17, 2020 Report Share Posted August 17, 2020 I saw someone (an idiot) driving around alone with a mask on. 2 Quote Link to comment
wayno Posted August 17, 2020 Report Share Posted August 17, 2020 That is where this is heading, I suspect soon you will be required to wear a mask if you are even outside your house, I heard this on the news, wear a mask if your even taking a walk by yourself, but this was news about the Portland OR area. 30 minutes ago, datzenmike said: I saw someone (an idiot) driving around alone with a mask on. 1 Quote Link to comment
angliagt Posted August 17, 2020 Report Share Posted August 17, 2020 My Wife saw someone driving with a mask on. Funny thing is,it was a convertible,with one person in it. i see people driving with masks AND gloves on, & nobody else in their car. 1 Quote Link to comment
Ooph! Posted August 17, 2020 Report Share Posted August 17, 2020 One of the US Presidential candidates has openly declared he would make masks mandatory everywhere, outside. 2 Quote Link to comment
datzenmike Posted August 18, 2020 Report Share Posted August 18, 2020 Masks are better than nothing but barely measurably better. Cloth masks are even less effective and a bandanna next to useless. Looks like you are actually doing something though and perception is everything. I suggest you don't go out at all without a good reason. Then at less than peak volume times when most are at home. Change how you do things, simply avoid other people. Limit your exposure. Like abstinence to prevent pregnancy rather than relying on prophylactic measures. The N95 only stops 95% of particles down to 0.3 microns. Viruses are almost 0.3 microns and smaller so only good for droplets above 0.3 microns. I have a P100 dust mask with cartridges. Good for 99.97% filtration down to 0.3 microns. Quote Link to comment
tr8er Posted August 18, 2020 Report Share Posted August 18, 2020 4 hours ago, datzenmike said: I saw someone (an idiot) driving around alone with a mask on. Here, I see it every day. Several times. Especially company vehicles. No sneezes on the steering wheel for the next guy. Quote Link to comment
tr8er Posted August 18, 2020 Report Share Posted August 18, 2020 1 hour ago, datzenmike said: Masks are better than nothing but barely measurably better. Cloth masks are even less effective and a bandanna next to useless. Looks like you are actually doing something though and perception is everything. I suggest you don't go out at all without a good reason. Then at less than peak volume times when most are at home. Change how you do things, simply avoid other people. Limit your exposure. Like abstinence to prevent pregnancy rather than relying on prophylactic measures. The N95 only stops 95% of particles down to 0.3 microns. Viruses are almost 0.3 microns and smaller so only good for droplets above 0.3 microns. I have a P100 dust mask with cartridges. Good for 99.97% filtration down to 0.3 microns. The entire premise to your argument is based on efficacy for the wearer. The idea is to protect anyone in your vicinity from you. The droplets a cloth mask block from getting out are not trivial. And the entire issue is that it requires everyone to participate. If everyone wears a mask aside from the one sick asshole, then all the others protection is basically worthless. If the sick guy wears a mask, everyone gets to tuck their kids into bed and break bread with family. The shower meme got a laughter out of me, but basically shaming people for making you safer feels especially naive. If folks drive with a mask, I feel good knowing they have a clean trail. More of them means we may once again be able to travel and enjoy life. Quote Link to comment
Mattndew76 Posted August 18, 2020 Author Report Share Posted August 18, 2020 Masks are a prophylaxis method of futility. No matter how much you protect your lungs from inhaling micron sized droplets your eyes are still exposed. The pathway of entry isnt just the mouth or nose. Its why the big flatulent faced screamers getting mad at anyone not wearing a mask is just parroting without any learned effort. Protect your eyes too people. Quote Link to comment
john510 Posted August 18, 2020 Report Share Posted August 18, 2020 Most of us masked up.The spread didn't stop. 2 Quote Link to comment
thisismatt Posted August 18, 2020 Report Share Posted August 18, 2020 People around here ride bikes with masks on...on rural roads 😂 Quote Link to comment
datzenmike Posted August 18, 2020 Report Share Posted August 18, 2020 1 hour ago, tr8er said: The entire premise to your argument is based on efficacy for the wearer. The idea is to protect anyone in your vicinity from you. The droplets a cloth mask block from getting out are not trivial. And the entire issue is that it requires everyone to participate. If everyone wears a mask aside from the one sick asshole, then all the others protection is basically worthless. If the sick guy wears a mask, everyone gets to tuck their kids into bed and break bread with family. The shower meme got a laughter out of me, but basically shaming people for making you safer feels especially naive. If folks drive with a mask, I feel good knowing they have a clean trail. More of them means we may once again be able to travel and enjoy life. And now you're saying that if a sick person wears one everyone is safe and that's just wrong. They're better than nothing. Stops or slows larger droplets from a cough or sneeze or forceful talking that will fall out of the air sooner. Slows the fine stuff down but much less stopping power. If you can breath through them, stuff can go either way. Cloth masks and bandanas are a joke. None come with a filtration rating they simply look reassuring to everyone. 1 Quote Link to comment
