datzenmike Posted September 30, 2021 Report Share Posted September 30, 2021 Brakes will cause the wheels on the front and the wheels and axle on the rear to try to move the opposite direction you are going. Clunk from the front??? Could be worn tension rod bushings. But I would imagine it would do it all the time. Clunk on the rear? My 620 frame rotted out of sight and the leaf spring mount separated and would clunk, but again it was continuous. Probably the sliding brake adjusters in the backing plates. They self adjust and center themselves once the brakes are tight against the rims, but once centered, they should stay there and move only as the shoes wear down. If the brakes are not adjusted snug enough this might be the cause. A broken return spring? I would look at all of them and see about a little brake grease on the rubbing points the metal parts of the shoes make with the backing plate. Maybe a shoe is hanging up when the pedal is released. There is a good chance the 521 used leading and trailing shoes. This is characterized by the lining on one shoe being closer to the wheel cylinder and the other closer to the adjuster on the bottom. If not careful it's possible to have two leading shoes on one side and two trailing on the other or simply a trailing shoe in the leading shoe position. Not all shoes are this way but the intent is that the forward motion adds a significant amount of extra friction to the shoe moving in the direction of travel. If you stop better backing up chances are they are reversed. Like I say the 521 may have come with leading and trailing or they may have been replaced with evenly lined shoes. Old Doges were notorious for grabby brakes in the morning the first time you used them when it was damp. Always good to drag the brakes for half a block to warm them. This was my '64 and probably asbestos linings back then. Quote Link to comment
a.d._510_n_ok Posted September 30, 2021 Report Share Posted September 30, 2021 COVID-19’s latest bizarre side effect: ‘Restless anal syndrome’ https://nypost.com/2021/09/30/covid-19s-latest-odd-side-effect-restless-anal-syndrome/ 2 Quote Link to comment
datzenmike Posted October 1, 2021 Report Share Posted October 1, 2021 Thanks for the laugh. Better add it to the growing list of true reasons to NOT get the vaccine. Quote Link to comment
Dguy210 Posted October 1, 2021 Report Share Posted October 1, 2021 (edited) 10 hours ago, datzenmike said: Brakes will cause the wheels on the front and the wheels and axle on the rear to try to move the opposite direction you are going. Clunk from the front??? Could be worn tension rod bushings. But I would imagine it would do it all the time. Clunk on the rear? My 620 frame rotted out of sight and the leaf spring mount separated and would clunk, but again it was continuous. Probably the sliding brake adjusters in the backing plates. They self adjust and center themselves once the brakes are tight against the rims, but once centered, they should stay there and move only as the shoes wear down. If the brakes are not adjusted snug enough this might be the cause. A broken return spring? I would look at all of them and see about a little brake grease on the rubbing points the metal parts of the shoes make with the backing plate. Maybe a shoe is hanging up when the pedal is released. There is a good chance the 521 used leading and trailing shoes. This is characterized by the lining on one shoe being closer to the wheel cylinder and the other closer to the adjuster on the bottom. If not careful it's possible to have two leading shoes on one side and two trailing on the other or simply a trailing shoe in the leading shoe position. Not all shoes are this way but the intent is that the forward motion adds a significant amount of extra friction to the shoe moving in the direction of travel. If you stop better backing up chances are they are reversed. Like I say the 521 may have come with leading and trailing or they may have been replaced with evenly lined shoes. Old Doges were notorious for grabby brakes in the morning the first time you used them when it was damp. Always good to drag the brakes for half a block to warm them. This was my '64 and probably asbestos linings back then. Wait a minute are you cluttering up our covid shitfest thread with car talk? Edited October 1, 2021 by Dguy210 2 3 Quote Link to comment
angliagt Posted October 1, 2021 Report Share Posted October 1, 2021 Hey - she's the expert. Quote Link to comment
datzenmike Posted October 1, 2021 Report Share Posted October 1, 2021 7 hours ago, Dguy210 said: Wait a minute are you cluttering up our covid shitfest thread with car talk? 1 Quote Link to comment
Dav Posted October 1, 2021 Report Share Posted October 1, 2021 17 hours ago, Dguy210 said: Wait a minute are you cluttering up our covid shitfest thread with car talk? It was tied back to the universal truths about Datsuns and the bungee cord n brick - I use rope n a chock. I did add a question about why rear brakes clunk early in the morning, trying to kill two birds with one post and save the world? Yes, how dare we. Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 Well my thermo is popping red at 100 degs. Not to sound too nihilistic but I am crossing my fingers that this is the Covidicus. 1 Quote Link to comment
thisismatt Posted October 2, 2021 Report Share Posted October 2, 2021 Dreaming of coronacation? Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 (edited) Meh I'm self employed so no coronacation for me. I want that natural immune response though. Edited October 2, 2021 by Mattndew76 Quote Link to comment
bottomwatcher Posted October 2, 2021 Report Share Posted October 2, 2021 Hmm you know the difference between an oral and anal thermometer? The anal tastes like shit! Anyways hope you don't have the vid. I think that would dampen the beer drinking experience I know I don't want that. 1 1 Quote Link to comment
datzenmike Posted October 2, 2021 Report Share Posted October 2, 2021 2 hours ago, Mattndew76 said: Meh I'm self employed so no coronacation for me. I want that natural immune response though. If only there were a way to get the immunity without having to getting sick.... Hey Matt, does that thermometer have wi fi? Expect the co-vid police any moment. 1 1 Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 (edited) Yeah its called nasal spray DNA delivery. Almost as effective as natural immunity unlike the jabs. Edited October 2, 2021 by Mattndew76 Quote Link to comment
Ooph! Posted October 2, 2021 Report Share Posted October 2, 2021 3 hours ago, Mattndew76 said: Well my thermo is popping red at 100 degs. Not to sound too nihilistic but I am crossing my fingers that this is the Covidicus. Are you prepped for home treatment ? what's your plan if it is? Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 20 minutes ago, Ooph! said: Are you prepped for home treatment ? what's your plan if it is? Ride it out, or die. Pretty much the same as I do with influenza. 2 Quote Link to comment
datzenmike Posted October 2, 2021 Report Share Posted October 2, 2021 Nun porn. Nun porn gets me through the day. 1 1 Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 Still burning. 1 Quote Link to comment
datzenmike Posted October 2, 2021 Report Share Posted October 2, 2021 Fuck, are you alright? What am I saying? That's not a good indication. Treat the symptoms. Acetaminophen will lower it some. Maybe let up on the nun porn.... or floor it. If you're going to hell anyway might as well drift in like a boss. 1 1 Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 I’m back to 100°. Tolerable again. Got to 104° And felt pretty intense. My eyes feel cooked lol. 2 1 Quote Link to comment
Mattndew76 Posted October 2, 2021 Author Report Share Posted October 2, 2021 Still mild grade fever and rattle cough but all in all so far so good. I’m sitting in the sunshine on the south porch. I hate closed off rooms. I made sure the wife opened our windows on the house to get some fresh air circulation since this virus thrives on poor air circulation. 4 Quote Link to comment
datzenmike Posted October 3, 2021 Report Share Posted October 3, 2021 Still with us Matt????? Quote Link to comment
