thisismatt Posted February 29, 2020 Report Share Posted February 29, 2020 24 minutes ago, datzenmike said: Again the start signal voltage should be measured and shown to be the cause. Yer puttin' yer boots on before looking out the window for rain. On 2/25/2020 at 9:32 PM, thisismatt said: Definitely sounds like a problem with the starter or associated wiring. 23 hours ago, thisismatt said: regardless A start relay is a good idea. It'll make your ignition switch last longer. Quote Link to comment
Eomund Posted March 2, 2020 Author Report Share Posted March 2, 2020 On 2/28/2020 at 6:20 PM, datzenmike said: Again the start signal voltage should be measured and shown to be the cause. Yer puttin' yer boots on before looking out the window for rain. Start signal is fine. I am pretty sure I found the issue. My key cylinder has been giving me some issues for a couple of months (the return spring was not working right) so I swapped it out also knowing it might be related to my problem. I've been driving a lot for the last several days with no issues. Not a guaranteed fix as intermittent is a bitch to track. But I've driven a lot and no issues thus far. On 2/28/2020 at 6:46 PM, thisismatt said: While there are plenty of work arounds, this bypass being one. I generally agree with Mike that it should be correct rather than bypassed. There are fuses and what not in the correct line and I generally don't like going around those. The new key seems to have done the trick. I've considered a start button instead of using the key as these cheap ass keys keep breaking. But I still think going through the stock relay is correct. Quote Link to comment
banzai510(hainz) Posted March 2, 2020 Report Share Posted March 2, 2020 1 hour ago, Eomund said: I generally don't like going around those the later Nissans went to a Hotstart relay from the factory that worked off the key switch. if you have a new switch it might work but as these vehicles get older more corrosion happens and the resistance goes up and happens again. that why Nissan added the reley triggered by a low voltage relay. I didn't want to do this either and got a new switch. I added a Ford relay on my 521 and NEVER installed the new switch. Now it seems my cheap ass Orileys starter is lasting longer than 2 years. So I was getting rid of good starters. as O Rileys said they were good but I thought they were fullof shit and swapped them out anyways(lifetime wareenty) Quote Link to comment
thisismatt Posted March 2, 2020 Report Share Posted March 2, 2020 3 hours ago, Eomund said: Start signal is fine. I am pretty sure I found the issue. My key cylinder has been giving me some issues for a couple of months (the return spring was not working right) so I swapped it out also knowing it might be related to my problem. I've been driving a lot for the last several days with no issues. Not a guaranteed fix as intermittent is a bitch to track. But I've driven a lot and no issues thus far. While there are plenty of work arounds, this bypass being one. I generally agree with Mike that it should be correct rather than bypassed. There are fuses and what not in the correct line and I generally don't like going around those. The new key seems to have done the trick. I've considered a start button instead of using the key as these cheap ass keys keep breaking. But I still think going through the stock relay is correct. It's not a bypass. You still use all your stock wiring, except you trigger a relay with it instead. Relay then fires your solenoid with power directly from the battery, instead of running 10-30 amps through your ignition switch. Quote Link to comment
datzenmike Posted March 2, 2020 Report Share Posted March 2, 2020 Done properly it's a properly fused relay powering the starter solenoid (which is basically a larger relay itself) Quote Link to comment
banzai510(hainz) Posted March 2, 2020 Report Share Posted March 2, 2020 16 gauge should be more than enuff most people don't add the fuse Quote Link to comment
