Crashtd420 Posted May 28, 2020 Report Share Posted May 28, 2020 7 hours ago, Jstocks said: No one makes an adjustable upper control arm? There must be a lot to out there to allow a more modern set up. I'm thinking of making the shock tower a little taller so I can run an air shock in the front as well and a heavy duty bump stop of course, I'm not worried about power steering at all. The upper control arm outer bushings are hammered out so I have some new ones, the bolts are also toast I think. The front drums are in rough shape, I'm going to pull them tomorrow and sand blast them in hopes of reuse. The front wheel bearings are also messed up, I hope I can find some new ones. Watch out with the front inner wheel bearing.. unless something changed the inner sold on sights like rock auto, autozone, among others are actually wrong .... Best to check the numbers on the bearing.... I believe it's a 32kb02.... They also have the 32kb02-11b which is for the 620.... it can be used but you have to remove a spacer from the spindle then you need a thin spacer .... Mikeklotz was making them, not sure if he still is .... I snagged a set for the furture.... 1 Quote Link to comment
Crashtd420 Posted May 28, 2020 Report Share Posted May 28, 2020 Also beebani makes some upgrades for the front end.... https://www.ebay.com/itm/192912532398 1 Quote Link to comment
Charlie69 Posted May 28, 2020 Report Share Posted May 28, 2020 (edited) If you buy one of Mike Kltz's brake kits it will set you up with 720 hubs and bearings. You will need to source hubs, calipers and rotors. I probably have a sey of hubs or Mike Klotz might have hubs also. The calipers I would get remanufactured and the rotors you buy new. Or the Beebani kit. Edited May 28, 2020 by Charlie69 2 Quote Link to comment
gene knight Posted May 29, 2020 Report Share Posted May 29, 2020 i have a guy who wants to upgrade his front brakes on his 521 1 Quote Link to comment
