Payco Posted February 18, 2020 Report Share Posted February 18, 2020 (edited) Guys Will 14x7 ET +6 and 14x8 ET +0 PCD 4X114.3 fit my 510 SSS Coupe. Think they will but want to have it confirmed by the experts. Can you also share your advice on what tyre sizes you would look to fit as I want to ensure I can source tyres too. Thanks Martin Edited February 18, 2020 by Payco Quote Link to comment
banzai510(hainz) Posted February 18, 2020 Report Share Posted February 18, 2020 To me I would pass on those wheels. If you have stock struts the wheel will stick out. 8 inch is getting to wide with zero offset!!!!!!!!!! I fit 15x7 +25mm Quote Link to comment
datzenmike Posted February 18, 2020 Report Share Posted February 18, 2020 Most ever was 9" wide but stars must align and sacrifice a chicken for this to happen. Eight inch is do-able but beyond most owners. Seven is much better and it's a 510 you don't need them that wide. Run 3/4" -1" narrower on the fronts to make the rears look wider. 1 Quote Link to comment
Payco Posted February 18, 2020 Author Report Share Posted February 18, 2020 Thanks Guys. Quote Link to comment
BrandonS Posted February 18, 2020 Report Share Posted February 18, 2020 (edited) I would say pass, but it really depends on what you want to do with your car. They will fit nice if you want to run tons of camber and slam it. If you want to run appropriately wide tires on them for their width and have a low, sporty suspension you will run into problems. I've since gotten a few different wheels for mine because of these not being optimal for the direction I'm going. This is a 14x7 +8 on the front of my coupe with a 175 stretched over it. You 7" +6 would be about the same, but would technically stick +2mm out farther. This is a 14x7.5 +1 on my Coupe with a 175 tire stretched over it. An 8" 0-offset wheel would stick out 7mm more than this. This is what stock 510's do when you lower them in the rear, they add tons of camber. Generally, you'll want to fix this with some brackets that allow you to dial out camber. If you do this though, you'd run into problems rubbing because the top of the wheel will come out as the bottom goes in. You can see how close the tire is to the inner fender lip here. With this setup I only had the option to run the tons of rear camber just to make the wheel fit. Edited February 18, 2020 by BrandonS Quote Link to comment
rosso Posted February 18, 2020 Report Share Posted February 18, 2020 Here is a great website that allows you to compare two tire/wheel combinations at the same time to see how it affects rim placement/offset and tire clearance to suspension and fenders. I use it all the time. http://www.rimsntires.com/specspro.jsp You can enter the size from one of the posters here and then your sizes to compare. 1 Quote Link to comment
Payco Posted February 19, 2020 Author Report Share Posted February 19, 2020 Thanks guys. Wont be pursuing these as not the fitment I am looking for. Quote Link to comment
banzai510(hainz) Posted February 19, 2020 Report Share Posted February 19, 2020 You want ez fitment in a 7in wheels its going to be +20 thru +25 stock struts. if you have 15x 6inch you have more leeway. Quote Link to comment
r0p0doe Posted February 20, 2020 Report Share Posted February 20, 2020 Are you going to source yourself some ZX struts? Quote Link to comment
4perrev Posted March 9, 2020 Report Share Posted March 9, 2020 On 2/18/2020 at 10:02 AM, rosso said: Here is a great website that allows you to compare two tire/wheel combinations at the same time to see how it affects rim placement/offset and tire clearance to suspension and fenders. I use it all the time. http://www.rimsntires.com/specspro.jsp You can enter the size from one of the posters here and then your sizes to compare. Great site!! Quote Link to comment
BrandonS Posted March 10, 2020 Report Share Posted March 10, 2020 I would like to add, as a Dad, I love the cheesiness of your title. I chuckle inside every time I see it. 1 Quote Link to comment
Payco Posted March 16, 2020 Author Report Share Posted March 16, 2020 thought I would be creative with the spelling given the topic Quote Link to comment
