zetabird Posted February 12, 2020 Report Share Posted February 12, 2020 looks like at some point i am going to have to replace my clutch, are there any option other than a stock like replacement. i can get a kit from napa for faily cheap Quote Link to comment
Tom1200 Posted February 14, 2020 Report Share Posted February 14, 2020 You will likely have to get a clutch kit, $50-$75 on Rockauto, I assume NAPA is similar. I use the stock parts in the 1200 I race; even with the A15 that makes 99hp at the wheels and I never had clutch issues (other than when I mal-adjusted the MC push rod.....doh!) Quote Link to comment
zetabird Posted February 18, 2020 Author Report Share Posted February 18, 2020 thats what i was thinking, thanks, ill proly do that over next winter if the one lasts that long Quote Link to comment
Dguy210 Posted February 19, 2020 Report Share Posted February 19, 2020 (edited) On 2/12/2020 at 12:20 PM, zetabird said: looks like at some point i am going to have to replace my clutch, are there any option other than a stock like replacement. i can get a kit from napa for faily cheap Which 5 speed do you have? 78 I'm assuming the 63 dogleg. You will need to make sure you get the 24 spline clutch (L series sizing) instead of the 18 spline (18 spline is later 60 series 5 speeds). I would also suggest looking for a clutch alignment tool that is specific as every clutch kit I've purchased for the dogleg seems to come with the wrong clutch alignment tool (shaft is the larger L series size). Maybe they have fixed this by now. http://datsun1200.com/modules/mediawiki/index.php?title=63-Series_Transmission Edited February 19, 2020 by Dguy210 Quote Link to comment
zetabird Posted February 19, 2020 Author Report Share Posted February 19, 2020 ill have to check. that, im not sure. ive only been under it to rig some exhaust on it.... the front of the pipe broke off and fell whe the PO was driveing and rolled the entire exhaust up into a ball..... Quote Link to comment
Tom1200 Posted February 20, 2020 Report Share Posted February 20, 2020 You should be able to get a small mirror up inside the tunnel and read the number on the side of the transmission. It should be a 63 series gearbox. Quote Link to comment
zetabird Posted February 20, 2020 Author Report Share Posted February 20, 2020 ill check that, i need to get it back into work so i can get under it anyway and change the fluid in the trans. got two of my new tires just need to order a wheel so i can get it fitted and see where i have to trim the wheel arch for the flares. Quote Link to comment
