MiltonV Posted February 6, 2020 Author Report Share Posted February 6, 2020 1 hour ago, wayno said: This is what the shift lever is supposed to look like and how long it is. Yours appears to have been modified, personally I would remove yours and find another shift lever off something local and weld what you want together between the 2 levers, perhaps sleeve over the weld to make it stronger, it will likely be expensive to ship a lever to you. That's exactly what I'm trying to do, but find locally is almost impossible since these model were very rare, that's why I'm trying to get the measures and see if I can make it from scratch. 1 Quote Link to comment
MiltonV Posted February 6, 2020 Author Report Share Posted February 6, 2020 1 hour ago, wayno said: This is what the shift lever is supposed to look like and how long it is. Yours appears to have been modified, personally I would remove yours and find another shift lever off something local and weld what you want together between the 2 levers, perhaps sleeve over the weld to make it stronger, it will likely be expensive to ship a lever to you. I have a shipping address in Miami, so shipping cost would be locally, if you want to sell that let me know how much would it be with shipping to FL 33195 1 Quote Link to comment
MiltonV Posted February 6, 2020 Author Report Share Posted February 6, 2020 54 minutes ago, Charlie69 said: My 4 speed shifter is sort also. It is 10 3/4" measured as in Waynos picture. That looks different from waynos picture, so which one would be the correct for a '71 with J13 motor? 1 Quote Link to comment
Crashtd420 Posted February 6, 2020 Report Share Posted February 6, 2020 18 minutes ago, MiltonV said: That looks different from waynos picture, so which one would be the correct for a '71 with J13 motor? They are same.... waynos is just removed from the lower bushing.... 1 1 Quote Link to comment
wayno Posted February 6, 2020 Report Share Posted February 6, 2020 I sent a message. 1 Quote Link to comment
datzenmike Posted February 7, 2020 Report Share Posted February 7, 2020 8 hours ago, MiltonV said: Yes,the shift lever, that's the part or measure I need, the length from the base all the way to the base of the knob Well my first post is fine. Any length that's comfortable for YOU is perfect. Don't over think this you don't need it to the mm. It could be a meter long and work. On 2/5/2020 at 12:30 PM, datzenmike said: It's not that critical. Any length or thickness that's comfortable to use is fine. You should be able to shift sitting with shoulders back against the seat without leaning forward. You can also put a small bend in it. Thread the end for any knob that is handy. 1 Quote Link to comment
pidge Posted February 7, 2020 Report Share Posted February 7, 2020 (edited) Pretty sure I’ve seen those on eBay before. Have you tried that route? I just did a search on there and seen at least one pop up. Can’t copy paste the link, but I typed in “Datsun 521 shifter” -Pidge edit: https://imgur.com/a/fzJN6QI https://imgur.com/a/b3JHygH Edited February 7, 2020 by pidge 1 1 Quote Link to comment
MiltonV Posted February 7, 2020 Author Report Share Posted February 7, 2020 1 hour ago, datzenmike said: Well my first post is fine. Any length that's comfortable for YOU is perfect. Don't over think this you don't need it to the mm. It could be a meter long and work. I know myself, I'm very orthodox about these things and my intention is to restore this car as much as original I can. 1 Quote Link to comment
Charlie69 Posted February 7, 2020 Report Share Posted February 7, 2020 17 hours ago, wayno said: This is what the shift lever is supposed to look like and how long it is. Yours appears to have been modified, personally I would remove yours and find another shift lever off something local and weld what you want together between the 2 levers, perhaps sleeve over the weld to make it stronger, it will likely be expensive to ship a lever to you. Waynos is correct for the 521. His is almost 14" long mine is 10 3/4" long. Not sure what the transmission I have came out of. Might have been a 710 goon. Quote Link to comment
