banzai510(hainz) Posted February 5, 2020 Report Share Posted February 5, 2020 (edited) in theory it can can 180 out if one removed the pedestal and put it on 180 the rotor will be in same spot but one has to pull the plug wires out of the dist cap and move them. some people do this incase they want the vacuum adv in a different spot. If the motor is mechanically timed then you need to elelctricall time it with the distributor plug wires ect…. fire order. Now ouring gas in the carb is a way to get it to fire if timed right. there is enough vapor to fire off if its close. once you think you have that(shows your electrical is working) you need to then look at the carb for vaccum leaks ect if still no start but starts if gas is poured in. Edited February 5, 2020 by banzai510(hainz) 1 Quote Link to comment
datzenmike Posted February 5, 2020 Report Share Posted February 5, 2020 Hah, I was assuming the OP would notice the vacuum advance hose wouldn't reach or the can was in the way of the rad hose. 1 Quote Link to comment
banzai510(hainz) Posted February 5, 2020 Report Share Posted February 5, 2020 with Scrapson one has to also maybe introduce a new proplem 1 Quote Link to comment
Scrapson Posted February 5, 2020 Author Report Share Posted February 5, 2020 ill watch hainz video to make sure everything is correct but it should not take to much to adjust that? Ill check for a vacuum leak but that seems hard to do without it running ya think? yes the vacuum advance line does reach from the carb to the distributor. also I should reset the distributor advance and retard back to zero? time to find hainz' video. Quote Link to comment
banzai510(hainz) Posted February 5, 2020 Report Share Posted February 5, 2020 just turn the dist back and forth and in the middle ans see what it does. If a huge vaccuum leak it wont run unless you just pump the gas and maybe have the choke fully ON Quote Link to comment
Scrapson Posted February 6, 2020 Author Report Share Posted February 6, 2020 the choke is electric but it has power when I turn the key. I set it to the middle to see. I’ll check for any vacuum leaks I can test without it running like distributor advance line and brake booster. Also the carb plate. Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 So update the cam sprocket keeps spinning off It seems to me like it’s a dowel that’s broken I’m just going to get a new cam shaft dowel pin and see if that helps too. It is torqued to spec which is 108ft-lbs I believe also the tensioner is in place and everything is fine it’s as soon as I try to start the motor it’ll just spin the sprocket. Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 What??? Set to TDC correctly. Block the tensioner from falling out. Remove the cam sprocket and look. If the cam dowel is broken.... Grab the cam in the middle with vice grips. Right here where the square bumps are and not on or near the lobes. Try to turn the cam, but not more than 1/2". Can you move it? Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 The cam shaft moves fine I moved it to reset the timing because the sprocket slipped before Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 Then the dowel must be snapped. Or missing! I'm cringing if the engine turns and the cam isn't. Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 Where do I find a replacement dowel then because I honestly am at a loss right now it’s one thing after another. Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 Is it missing? Could the cam have snapped behind the cam sprocket? Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 If it did I’m going to shit a brick and take it to someone. How could the cam have snapped? Is the dowel pin that goes into the hole apart of the cam or no? Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 It's part of the cam, or it's pressed into the cam. Is it missing or broken because we can discuss this all night and get no where. Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 Definetly broken because 2 nights ago it was there but it did seem a little shorter and then we gave her the extra ugga Durga and it just moved a little extra than I thought but didn’t think anything of it then last night we noticed the sprocket was off the dowel. Quote Link to comment
wayno Posted February 8, 2020 Report Share Posted February 8, 2020 My first question would be is the starter strong enough to shear the dowel off if a valve is jammed against a piston? Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 The 100 ft lb bolt should hold the sprocket on. The dowel is simply for alignment. Is the fuel pump eccentric on there? The bolt may have bottomed out without gripping the sprocket. Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 (edited) The starter I doubt has the power to do so but the other thing is that the sprocket got wollored out ill post pictures in a second of it. The dowell is pretty tattered up but it held the sprocket on. It looks like the sprocket is done for so I’m ordering a new one. The fuel eccentric bolt was on and it was as tight as A *insert dirty joke* it was on there that’s for sure I mean she had the full ugga dugga maximum Edited February 8, 2020 by Scrapson Ugga dugga Quote Link to comment
Scrapson Posted February 8, 2020 Author Report Share Posted February 8, 2020 https://ibb.co/bH876yn https://ibb.co/Tg4CQmr Quote Link to comment
G-Duax Posted February 8, 2020 Report Share Posted February 8, 2020 3 hours ago, datzenmike said: What??? Best dam paw/face ever ! 1 Quote Link to comment
wayno Posted February 8, 2020 Report Share Posted February 8, 2020 (edited) If you don't have any bent valves it will be a miracle, I suspect that the cam sprocket did not settle onto the dowel like it was supposed to, that it was not on there crooked enough to see that it was crooked is baffling to me, that gear looks like the gear turned and the cam didn't and that is likely why it was loose. One of the first things I would do now is look at all the valve spring heights from the side, if a spring is lower or a rocker all of a sudden was looser than it should be you likely have a bent valve. I can say this with certainty, you cannot spin the crank with the head on the block and the cam not turning, a valve is going to get bent if not valves get bent, if none of them got bent it is a freaking miracle. I don't know how your going to do it, but if none of them were bent your going to have to somehow get the can back to 10am/2pm and then get the block back to TDC without screwing anything up, valves can hit the pistons and get bent. Edited February 8, 2020 by wayno Quote Link to comment
Jersey Posted February 8, 2020 Report Share Posted February 8, 2020 I once had a cam snap on my L18 just behind #3 cam tower. It still ran on the remaining 3 cylinders. That sprocket looks like you had zero dowel engagement...weird. Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 Not the bolt. The fuel pump eccentric / washer under it. The thing that works the pump arm. If left off the bolt will tighten into the cam farther and might tighten up but not hold the sprocket. Just a guess. As wayno said the sprocket would be cocked slightly if tightened onto the dowel without being in the hole on the sprocket. 11 hours ago, datzenmike said: Then the dowel must be snapped. Or missing! I'm cringing if the engine turns and the cam isn't. This cringe is the reason for the 'Paw Face'. Quote Link to comment
Stoffregen Motorsports Posted February 8, 2020 Report Share Posted February 8, 2020 I see two possibilities here - 1- the eccentric was left off, and Mike described what can happen there. 2- the cam sprocket was never actually engaged on the cam. They can be a bitch to get onto the cam sometimes. Chain tension that's tight can make it very hard to get the sprocket up high enough to engage on the cam register. Either way, if the bottom end spun a full rotation without the cam moving with it, there are probably some bent valves. Quote Link to comment
datzenmike Posted February 8, 2020 Report Share Posted February 8, 2020 If the cam remained at TDC..... unlikely as you can turn them with a small effort by hand and certainly a 100 ft lb tight bolt would hold the sprocket tightly enough. The scoring definitely shows that at some point the cam was stopped or stopped and started and the sprocket kept turning. Now this could be the point when a valve was stopped by a piston. The fuel pump eccentric is thick (0.25") and there is a thick lock washer. (0.15") Both add to 0.4". Assembled with the sprocket there is only 1/8" of thread left inside the cam before the bolt bottoms out. Even just the lock washer left off would be enough to the bolt bottoming out.... however the cam dowel would still be close to fully engaged in the sprocket. If both were off the bolt definitely would bottom and there would be about 0.275" of slack on the sprocket. The dowel sticks out only 0.26" so more than enough for the sprocket to slip back off. I may be off but it could explain the problem Quote Link to comment
