datzenmike Posted August 6 Report Share Posted August 6 You need to count the input teeth and the counter drive teeth below it. The counter shaft and mating gears above are basically The same. This ratio basically makes a transmission a wide, medium or close ratio. You may get a set for a zx and be very disappointed with the performance. I would guess you have a mid ratio 22/31 gear set but confirm. Quote Link to comment
