omanalansan Posted January 24, 2020 Report Share Posted January 24, 2020 Good morning, thanks guys for accepting/adding me to the group. I have a 1975 280z that I have been restoring for the past 2 months, a buddy of mine is selling me a set of new wheels/tire combo. I'm nervous of the fitment. can these fit? Rota Grid (white) 16x9 offset -15 225/50r16 tires let me know and thanks in advance Oman Quote Link to comment
datzenmike Posted January 24, 2020 Report Share Posted January 24, 2020 He's a friend so borrow one and put it on. If the tire is outside the fender lip it will rub on bad bumps and all the time if lowered. Look at it. If the body comes down will it hit the tire? Don't rely on stiffer springs to save you, eventually something will catch you by surprise like launching over some railway track intersection that you thought flat. Expect the worst and design for the best. Rule No 1... make the wheels fit the car not the car fit the wheels. The alternative is chopping the fenders lip off and covering your choice with flairs. This is an option if they are already rusted away. Quote Link to comment
Bleach Posted January 25, 2020 Report Share Posted January 25, 2020 At zero offset, a 225 width tire will rub ever so slightly in the rear but clear in the front when driving straight. At zero offset, you can have the rear fender lip rolled to clear and the front will rub sometimes when turning if the car is lowered more than 1 inch. So, pushing all the wheels out 15mm will make clearance much worse. You could put wheel spacers on to poke out further and just cut/flare the car. If you keep the car at factory height, it might fit fine and not rub until you go fast over a large bump! 😄 1 Quote Link to comment
datzenmike Posted January 25, 2020 Report Share Posted January 25, 2020 Maybe they don't fit his car. Sometimes it's best to just walk away. 1 Quote Link to comment
Racer X 69 Posted August 17, 2020 Report Share Posted August 17, 2020 On 1/24/2020 at 6:41 AM, omanalansan said: Good morning, thanks guys for accepting/adding me to the group. I have a 1975 280z that I have been restoring for the past 2 months, a buddy of mine is selling me a set of new wheels/tire combo. I'm nervous of the fitment. can these fit? Rota Grid (white) 16x9 offset -15 225/50r16 tires let me know and thanks in advance Oman Go here. https://www.wheel-size.com Quote Link to comment
