Quick release hub for 521 pickup
mikel521
  • Replies 2
It's the same as a roadster or 240Z. Spline count should be identical.
Amazon sent me one by accident and I test fit it on both my Datsuns and it was a match for both. It's made by Grant (if you want the whole hub and adapter together). Easiest to use a Grant steering wheel with it, as it's already drilled and tapped for the right hole pattern.
Edited by mainer311
