Captin840 Posted January 13, 2020 Report Share Posted January 13, 2020 I was driving along and both high/low head lights went out. Still had my park lights, went to check the fuses and they seemed fine other then one off them was very hot. Not sure if it's something in the wiring or the main headlight switch on the dash. Quote Link to comment
datzenmike Posted January 13, 2020 Report Share Posted January 13, 2020 The clips that hole the fuses get tarnished with age like an old penny. This causes resistance and when current flows through resistance it generates heat. If left this way the heat will soften and damage the clips so they don't grip the fuse properly and more heat. The fuses are soldered inside and the solder can melt and the fuse fails. The 620 fuse box unplugs easily and there are two screws holding it to the underside of the dash. Remove the entire box and note what fuses go where and remove them. Scrub it clean, then get a suitable size container and submerge the box is a mixture of lemon juice and table salt over night. The next day rinse off, dry and replace the fuses. Get a new 15 amp fuse for the headlights. Quote Link to comment
Captin840 Posted January 13, 2020 Author Report Share Posted January 13, 2020 Thanks man I appreciate it! Quote Link to comment
datzenmike Posted January 13, 2020 Report Share Posted January 13, 2020 The fuse has probably over heated and melted inside so replace it. My '78 headlights used to turn off and I got used to reaching down and rubbing the fuse to get it to make contact. I should have fixed the problem and it got worse and worse till the clips were all eroded and wouldn't hold the fuse. I eventually got another box and replaced it. The acid in lemon juice eats the tarnish of any copper alloy like brass. Here's mine after cleaning. Quote Link to comment
Old RC Rich Posted January 13, 2020 Report Share Posted January 13, 2020 While on this subject, I recently picked up a 620 and was wondering, if you flick the signal arm forward, are the high beams supposed stay on? If so, mine are opposite, pull to be on high beam, push forward for standard beam. Really seems awkward that i'm having to reach further forward to use the signals....I'll add that i do have a Nardi steering wheel with a momo adapter so maybe that's why it feels backwards? Sorry for the novice question but this is my first Datsun since my 73 240 I had in high school back in 1986 LOL Thanks Quote Link to comment
Captin840 Posted January 13, 2020 Author Report Share Posted January 13, 2020 That's exactly what the problem was thank you, good on yah! Quote Link to comment
datzenmike Posted January 13, 2020 Report Share Posted January 13, 2020 8 hours ago, Old RC Rich said: While on this subject, I recently picked up a 620 and was wondering, if you flick the signal arm forward, are the high beams supposed stay on? If so, mine are opposite, pull to be on high beam, push forward for standard beam. Really seems awkward that i'm having to reach further forward to use the signals....I'll add that i do have a Nardi steering wheel with a momo adapter so maybe that's why it feels backwards? Sorry for the novice question but this is my first Datsun since my 73 240 I had in high school back in 1986 LOL Thanks I can't remember how my 620 was but my 710 is forward for high beams. I think the pins in the connector plugging into the headlight relay could be poked out and re arranged to change it. On the earlier 620 the relay is on the rad support and later are on the passenger side inner fender. Quote Link to comment
banzai510(hainz) Posted January 13, 2020 Report Share Posted January 13, 2020 my 510 is one way my 521 is the opposite. who cares it works Quote Link to comment
datzenmike Posted January 14, 2020 Report Share Posted January 14, 2020 If serious about swapping the high beams to the forward position, find the headlight relay. I think between the rad and the right hand set of headlights. With just the headlights on flick hi and low and listen for the click of the relay. Once found, swap the Red/White strip wire with the Red/Black stripe. Quote Link to comment
Old RC Rich Posted January 14, 2020 Report Share Posted January 14, 2020 36 minutes ago, datzenmike said: If serious about swapping the high beams to the forward position, find the headlight relay. I think between the rad and the right hand set of headlights. With just the headlights on flick hi and low and listen for the click of the relay. Once found, swap the Red/White strip wire with the Red/Black stripe. Thanks it hasn't been a huge issue, just more curious and plan to try and fix it. Quote Link to comment
