JuanOch0a Posted January 12, 2020 Report Share Posted January 12, 2020 I took out the dash out of my 720 earlier when I wanted to look at the wiring, and in doing that i exposed tubes where air goes through to the vents. I tried to turn on the heat on and the blower motor sounded like it was working, but I looked over all vent tubes and nothing was coming out. Is there a way I can fix this? 1 Quote Link to comment
wayno Posted January 12, 2020 Report Share Posted January 12, 2020 Maybe your heater controls were in the off position. 1 1 Quote Link to comment
datzenmike Posted January 12, 2020 Report Share Posted January 12, 2020 Or cables have come off. 1 Quote Link to comment
Charlie69 Posted January 13, 2020 Report Share Posted January 13, 2020 Did you check for air movement out the defrost at the base of the windshield. Did you get all the plastic duct parts assembled and installed correctly. Quote Link to comment
Stoffregen Motorsports Posted January 14, 2020 Report Share Posted January 14, 2020 Sounds like the flapper door is shut. 1 Quote Link to comment
