SLO720 Posted January 10, 2020 Report Share Posted January 10, 2020 Hello all, I was wondering if the early 3 plug resistor could be wired to work in place of the 5 wire resistor found in the later model trucks. Any help would be great. Thanks again! 1 Quote Link to comment
datzenmike Posted January 10, 2020 Report Share Posted January 10, 2020 I don't see why not. You might have to poke out some of the pins and move them around on the plug. 1 Quote Link to comment
SLO720 Posted January 11, 2020 Author Report Share Posted January 11, 2020 So here is an update on what I've found looking through the service manuals. Somewhere in January of 1984 the resistor was updated to give blower 4 speeds (from what I can tell). The newer resistor is a 5 pin unit that only uses four pins. In switching to the earlier 3 pin unit you will loose 2 speeds and only have the high and low input. The way I have it wired I run the medium setting as "1" and the high setting at "3". Blue/Black goes to the center of the three pin relay. (With writing faced where its readable) I used blue/red as the top left, and solid blue as the top right. You could also in theory, take the later resistor and maneuver it into the earlier box, holding it in place with one screw. 2 Quote Link to comment
Madkaw Posted January 13, 2020 Report Share Posted January 13, 2020 Maybe that’s why I lost 2nd gear when I changed resistors ?! i have an 83 and put a later AC control unit in . 1 Quote Link to comment
