Bshot Posted January 5, 2020 Report Share Posted January 5, 2020 Question for you all, had a new wire harness made tuned up and driving my 64 320. Bought new battery and drove her for three days, then wouldn’t start. Trickled the battery for three days and same thing happened. Able to drive with a jump and get to where I needed to go (2-3 miles). Sent her back to the people that wired her and they said they can not find a draw and wired correctly. How can you tell if generator is bad or going bad? Any suggestion? I have them going over it one more time before I pick her back up Quote Link to comment
datzenmike Posted January 5, 2020 Report Share Posted January 5, 2020 Briefly, and I mean briefly, disconnect one of the battery cables while running. If the engine quits, it's not charging. Quote Link to comment
320 Newb Posted January 5, 2020 Report Share Posted January 5, 2020 If you're running a stock generator I'd prob just have to rebuilt for good measure. Are you running neg or pos ground? Quote Link to comment
DanielC Posted January 6, 2020 Report Share Posted January 6, 2020 Generators require a cut out relay in the voltage regulator. When the engine is NOT running, this relay disconnects the field windings in the generator from the battery. 1 Quote Link to comment
Bshot Posted January 6, 2020 Author Report Share Posted January 6, 2020 It’s there a picture where and what this relay looks like? Also running pos ground Quote Link to comment
banzai510(hainz) Posted January 6, 2020 Report Share Posted January 6, 2020 (edited) about 40 secs into the vid do this with a test light https://video.search.yahoo.com/search/video?fr=yfp-t&p=battery+drain+youtube#id=51&vid=418de20d5f3335af5d80b045562c43ac&action=click. Im not a Genorator expert but I would assume you still get above 13volts when its running 14 max.. 15 is over charging. a Gen is like pulsating DC current. its on off so fast you cant see it. get a volt meter and hook it up to the battery and read what it says. if lights get BRIGHTER when you rev it up the gen is good i WOULD THINK, just that you have a drain. do the test light test then pop a fuse till it goes away or disconnect the Gen or VR or relay as some on here says and see if the test lamp goes out them you found the drain source Edited January 6, 2020 by banzai510(hainz) Quote Link to comment
