nissan720 Posted December 21, 2019 Report Share Posted December 21, 2019 nissan part number 22119 coupling assy to fit my lb20 distributor .Who knows where you can order these from?Th anks in advance for the help Quote Link to comment
datzenmike Posted December 21, 2019 Report Share Posted December 21, 2019 All Nissan parts have a 10 digit code of 5 numbers plus a 5 number or number/letter combinations. The coupling set is 22119-W0400. It's a plastic collar and a roll pin to hold it. 22119-W0400 is common to all 240/260/280x and 280zx, 810 and Maxima six cylinder L series engines, All L and Z series engines after the 510 and 521 through '86.5 have it. Points or EI does not matter. You can try Nissan but very unlikely it will be available. With all theses distributors laying around, surely someone can find one for you. Try a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ ... Quote Link to comment
nissan720 Posted December 22, 2019 Author Report Share Posted December 22, 2019 thank you datzenmike thats a big help.you the man!! Quote Link to comment
nissan720 Posted December 29, 2019 Author Report Share Posted December 29, 2019 what type of grease do you use on the bearing plate assy when reuilding a distributor out of a 1979 .matchbox style distributor Quote Link to comment
datzenmike Posted December 29, 2019 Report Share Posted December 29, 2019 Wheel bearing grease should be fine. Quote Link to comment
