Droski Posted December 21, 2019 Report Share Posted December 21, 2019 (edited) I recently had a 5 speed trans installed into my 620 and few days ago I started hearing clanking sounds after shifting into gear (in all gears), the clanking noises last about a second or two and go away. Sometimes the sounds are not there. Edited December 21, 2019 by Droski Quote Link to comment
datzenmike Posted December 21, 2019 Report Share Posted December 21, 2019 You mean up shifting? 1 to 2, 2 to 3 and so on? Probably a loose exhaust pipe, muffler clamp or hanger. Climb under and give the exhaust a good shake. Quote Link to comment
wayno Posted December 21, 2019 Report Share Posted December 21, 2019 I would check the rubber piece at the carrier, if it has cracks and holes in it it might be hitting the frame that holds it in position, normally I would describe it as a clunk or knock, but if metal is hitting metal it might sound like a clang because the drive line can sound like a wind chime under the right conditions. Quote Link to comment
