jeremiahnz1 Posted December 20, 2019 Report Share Posted December 20, 2019 Hi All, Looking at fitting a 260z steering wheel on my 410. The spline is correct but it would slide all the way down and sit flush or engage the indicator canceller. I bought a cheap steering wheel adapter and the same applies. Anyone got any tips on fitting a different steering wheel and getting it to sit flush? TIA Quote Link to comment
MikeRL411 Posted December 21, 2019 Report Share Posted December 21, 2019 The factory steering wheel diameter on the 410 and 411 is correct for the front end geometry and steering gear worm. using a larger or smaller diameter steering wheel will result in over or under steer until you get used to the new response of slight wheel movements. Be careful and practice until you feel safe with new steering wheel changes. Quote Link to comment
