why so slow
frankb
Hi. Just picked up a 1968 520. Thing runs great, but only does about 45mph. I know it has 67hp, but my u521 has the same engine and will easily do 65mph. wondering what it could be. Just had the carb fixed and it's better, but I have no idea what else it could be. maybe the rear end? Any advice or mods would be greatly apprciated.
  • Replies 22
Can't be the rear end Nissan used the same one in the L521.
Check the fuel is at the line on the glass front of the carb.
Replace the fuel filter. Cost under $5 and no harm done if this isn't it.
Check the valve lash.
Check the timing.
To post a picture you will have to get a picture hosting account such as imgur. (but there are many others) Do NOT use Photobucket.... ever. Download and save your pictures there. Later go there and copy the picture information and bring it to Ratsun and paste it into the text.
  • 3 weeks later...
OK, so the plug has 4 wires.
How do you know the wiper motor is bad and it is not the switch that is bad, you sure the plug is making all the connections?
I ask because these trucks are getting old and wiring gets crusty, so again how do you know it is the motor that is bad.
I will look at my stash of wiper motors.
Edited by wayno
Well, when I pull the switch, the blades raise halfway and then they just freeze. That leads me to believe that the connections are being made to fire the motor, but then it seizes. I'm new to working on cars, so I could be wrong for sure. It just seems to me that it is the motor. Thanks so much!!!!! All of the similar motors I see have 5 prongs and different connectors
OK, first you need to disconnect the wiper assembly(transmission) from the wiper motor and see if you can move it with your hand without it dragging/seizing, if it moves freely then it is likely the wiper motor but I suspect it is one or both the pivots seizing from sitting too long without use.
First see if you can move them by hand disconnected from the wiper motor, if they don't move easily then try a lubricant of some kind, do not force them and break the wiper assembly as finding one of those will likely not be easy or cheap.
  • 1 month later...
I see a kid install a weber on a 510 and he didn't hook up the electric choke. I forgot if it was a org manual carb or not. Most J motors I assume are manual as the are older vehicle
2nd 510 I cked out the distributor wasn't pointing at TDC when I lined it up. But a timing light would catch this as oe could not get to 0-25 degs with the light. Believed he was to far advance(im guessing) reset dist and got more HP
