Droski Posted December 13, 2019 Report Share Posted December 13, 2019 (edited) My gas level gauge went from working to not working today , needle is at past empty (happened after visiting a gas station/has fuel). Fuel sending unit ? Edited December 13, 2019 by Droski Quote Link to comment
Draker Posted December 13, 2019 Report Share Posted December 13, 2019 Contacts might be dirty on the sweeper in the tank. If you pull the wire off and ground it, the gauge should read full. If it does then the issue is the sender. Probably just need to clean it. 1 Quote Link to comment
Droski Posted December 13, 2019 Author Report Share Posted December 13, 2019 I appreciate your help 🙏 Quote Link to comment
datzenmike Posted December 13, 2019 Report Share Posted December 13, 2019 Not sure if there is only the one wire to the sender in the tank. If so the tank is grounded. Loss of ground will also cause the gauge to not work. Make sure the tank is grounded. The wire from the gauge may also have corroded and fallen off. It's bundled into the rear light harness and clipped to the frame so is very exposed to rocks thrown by the tires. 1 Quote Link to comment
Droski Posted December 20, 2019 Author Report Share Posted December 20, 2019 also forgot to mention that my temperature gauge is also not working, didnt notice it at first but both are not reading could this be an electrical issue ? Quote Link to comment
bilzbobaggins Posted December 20, 2019 Report Share Posted December 20, 2019 (edited) Most likely a voltage regulator problem that is located inside the 620 cluster. Edited December 20, 2019 by bilzbobaggins added stuff 2 Quote Link to comment
datzenmike Posted December 21, 2019 Report Share Posted December 21, 2019 This! Remove the temperature gauge and locate the contact points. Fold a thin strip of fine emery cloth and place between the contacts. Pull the emery cloth out several times to clean them. Quote Link to comment
