weldingrod Posted December 6, 2019 Report Share Posted December 6, 2019 Somebody posted a schematic for all those friffin' 1/4" size rubber lines running all over the engine bay, shows one line going to passenger side (inner fender I am assuming) but I have 3 thingies there. 1984 720 4x4 xcab. Quote Link to comment
datzenmike Posted December 6, 2019 Report Share Posted December 6, 2019 There are two vacuum switches on the passenger side inner fender. One for low vacuum to switch off the exhaust side plugs and one for high vacuum to turn off the idle cut solenoid during high speed deceleration. I forget the other but will look it up when I get home. Quote Link to comment
datzenmike Posted December 7, 2019 Report Share Posted December 7, 2019 There should be a vacuum line diagram on the underside of the hood..... Quote Link to comment
weldingrod Posted December 7, 2019 Author Report Share Posted December 7, 2019 Decal gone but that looks more like what I should have. Runs ok (except for needing carb rebuilt) but only getting about 15 mpg. Have had a few 720's and should be getting twice that. I think the missing components might have something to do with that. Thanks Mike, your the go to source. Quote Link to comment
datzenmike Posted December 7, 2019 Report Share Posted December 7, 2019 On an Imperial gallon just over 20 is closer to what you should be getting. 1 Quote Link to comment
weldingrod Posted December 7, 2019 Author Report Share Posted December 7, 2019 Figured at least 20mpg because hardly over 4000 rpm around town. I know carb needs a rebuild, just have to figure out which kit to get. Older Nissans didn't emboss numbers on carb bodies, just attached a silly little aluminum tab to a carb screw and I have yet to see one that has lasted. Then, with carb and cleaner off, will replace ALL those little tubes. Quote Link to comment
