angelmanuel Posted December 5, 2019 Report Share Posted December 5, 2019 For the popular front strut swap, can Z31 300ZX struts/hub/spindles be used instead of 280ZX stuff? I can get the Z31 stuff readily and was wondering. Quote Link to comment
datzenmike Posted December 5, 2019 Report Share Posted December 5, 2019 I think you can if non turbo. Turbo ones are 5 lug rims. Quote Link to comment
angelmanuel Posted December 5, 2019 Author Report Share Posted December 5, 2019 I think they might be a little shorter which is not a bad thing. My concern was do they bolt on to the steering arm and ball joint. Thanks! Quote Link to comment
datzenmike Posted December 5, 2019 Report Share Posted December 5, 2019 I think they will, anything above the 69' 510??? has the larger bolt pattern? Kind of going by memory. I'm sure they have been used and the S12 struts Quote Link to comment
angelmanuel Posted December 5, 2019 Author Report Share Posted December 5, 2019 Thanks Mike. I guess I’ll try them Quote Link to comment
scooter Posted December 15, 2019 Report Share Posted December 15, 2019 i think the pin angle is different on z31 struts Quote Link to comment
datzenmike Posted December 15, 2019 Report Share Posted December 15, 2019 Strut to hub angle? Most are 10o including the zx but not the 240/260/280z. The 300zx might be different but I think I have heard of them being used on Datsuns. A 4 lug 280zx hub will fit the 300zx. Quote Link to comment
thisismatt Posted December 15, 2019 Report Share Posted December 15, 2019 Pretty sure no, you can't directly swap 300zx. It's been a while since I was researching this issue, but I'm almost 100% sure it's not a bolt-up affair. Quote Link to comment
datzenmike Posted December 15, 2019 Report Share Posted December 15, 2019 Maybe what I'm thinking is using the 5 bolt hubs on a zx strut. Quote Link to comment
angelmanuel Posted December 16, 2019 Author Report Share Posted December 16, 2019 dang that sucks. back to the drawing board then. Quote Link to comment
