510revisited Posted November 28, 2019 Report Share Posted November 28, 2019 So I'm interested in doing the zx swap for my 510. And being black friday (tomorrow) I'm scanning all the sites I can to find a deal for zx brake kits. I came across two kits. One for a 79-81 and another for 82-83. What's the difference. I have the struts for a zx in my garage, but..... I have no idea what year they are. I thought they were all the same for that model. Anyways, as always. Any and all is appreciated. Quote Link to comment
thisismatt Posted November 28, 2019 Report Share Posted November 28, 2019 As far as I know, fronts are all basically the same, but rears have more modern calipers on the later years. 1 Quote Link to comment
Str8jacket Posted November 28, 2019 Report Share Posted November 28, 2019 300zx ? The brake calipers are different. You can get 2 piston, 4 piston steel, 4 piston alloy, 26mm and 30mm rotors. The other zx's i have no idea Quote Link to comment
510revisited Posted November 28, 2019 Author Report Share Posted November 28, 2019 1 hour ago, Str8jacket said: 300zx ? The brake calipers are different. You can get 2 piston, 4 piston steel, 4 piston alloy, 26mm and 30mm rotors. The other zx's i have no idea Should have specified better. 280zx. 79-83 1 Quote Link to comment
datzenmike Posted November 29, 2019 Report Share Posted November 29, 2019 7 hours ago, 510revisited said: So I'm interested in doing the zx swap for my 510. And being black friday (tomorrow) I'm scanning all the sites I can to find a deal for zx brake kits. I came across two kits. One for a 79-81 and another for 82-83. What's the difference. I have the struts for a zx in my garage, but..... I have no idea what year they are. I thought they were all the same for that model. Anyways, as always. Any and all is appreciated. Front brakes are all the same but the pads likely were upgraded over the years. Just buy the best pads you can afford for them. Each strut tube has a part number stamped on the outside below the spring perch and just above the rotor. Use a wire brush. Post those numbers and I may be able to get a year they were used. There are two 5 digit numbers starting with 54302 (right hand).... the next digit will probably be a P and 4 more numbers. 54303 are left hand Quote Link to comment
510revisited Posted November 29, 2019 Author Report Share Posted November 29, 2019 Here are the ads. I had to take two screen shots.. Quote Link to comment
thisismatt Posted November 29, 2019 Report Share Posted November 29, 2019 Two sets because the rear brake hoses are different. Quote Link to comment
datzenmike Posted November 29, 2019 Report Share Posted November 29, 2019 There was no mention of rear brakes. Only front struts. Those pictures are useless and are of the '70-'78 S30 calipers. These are zx calipers and struts. All you need are new rotors (skip those ridiculous cross drilled things) and pads. The pads do all the work, so spend money on them. Say $100 for the rotors and $65 for the pads. If the calipers are leaking then new calipers otherwise wire brush them and spray them red or something. It's a 2,300 pound 510, the stock zx brakes are an insane upgrade to begin with. You'll never drive them hard enough to matter if you didn't spent $500 on them. Quote Link to comment
thisismatt Posted November 29, 2019 Report Share Posted November 29, 2019 1 hour ago, datzenmike said: There was no mention of rear brakes. Only front struts. Those pictures are useless and are of the '70-'78 S30 calipers. These are zx calipers and struts. All you need are new rotors (skip those ridiculous cross drilled things) and pads. The pads do all the work, so spend money on them. Say $100 for the rotors and $65 for the pads. If the calipers are leaking then new calipers otherwise wire brush them and spray them red or something. It's a 2,300 pound 510, the stock zx brakes are an insane upgrade to begin with. You'll never drive them hard enough to matter if you didn't spent $500 on them. He asked what the difference is and why there are different kits between year segments - because those kits include rear brake hoses and the rear hoses are different for 79-81 vs 82-83 1 Quote Link to comment
datzenmike Posted November 29, 2019 Report Share Posted November 29, 2019 Got it. Quote Link to comment
510revisited Posted November 29, 2019 Author Report Share Posted November 29, 2019 12 hours ago, thisismatt said: Two sets because the rear brake hoses are different. Why would they have rear hoses? Am I missing something? Shouldn't there only be one hose per side?? Quote Link to comment
thisismatt Posted November 29, 2019 Report Share Posted November 29, 2019 1 hour ago, 510revisited said: Why would they have rear hoses? Am I missing something? Shouldn't there only be one hose per side?? Rear of the car, not rear of the front struts. Quote Link to comment
510revisited Posted November 29, 2019 Author Report Share Posted November 29, 2019 9 minutes ago, thisismatt said: Rear of the car, not rear of the front struts. It just seems odd they'd add hoses for the rear of the car in a front of the car kit. Ok, well shell be ordered b4 the end of the night. Thanks for the clarification Quote Link to comment
datzenmike Posted November 30, 2019 Report Share Posted November 30, 2019 They replace the rubber hoses with braided SS? A dubious upgrade. Quote Link to comment
