banzai510(hainz) 4,717 Posted November 28, 2019 Report Share Posted November 28, 2019 Don’t my vedio show how to do this ? Especially on the chain install.I think I was pretty clear on the links and slack and tight side guide installation. Brite links on the sprocket dimples! Quote Link to post
Scrapson 23 Posted November 28, 2019 Author Report Share Posted November 28, 2019 I got the dimples right it’s just the crank has some play that threw me off. Quote Link to post
Scrapson 23 Posted November 28, 2019 Author Report Share Posted November 28, 2019 (edited) https://drive.google.com/file/d/1EhVlv2AMGaH3vZx3f5CEvWRIc4UVaKXU/view?usp=drivesdk https://drive.google.com/file/d/1DR1tzM6zDnrQ8c0j4FgA2yGBMGGCw2I_/view?usp=drivesdk Thats as far as I’ve gotten Edited November 28, 2019 by Scrapson Quote Link to post
banzai510(hainz) 4,717 Posted November 28, 2019 Report Share Posted November 28, 2019 That looks correct. clean up the area and you have to drop the oil pan abit so the gasket don’t rip when slipping the front cover on.You could buy a gasket and cut the front section and just use that.Others might say use some black rtv. I also but a cunt hair amount around the water port passages and up in the corners of the head.I assume the head is torque down already.dont pinch the head gasket in the corners.Do a couple dry runs on doing this Also once the front cover on do some dry runs on distributor install once you got it figured out make sure oil in oil pump with new gasket 1 Quote Link to post
Scrapson 23 Posted November 28, 2019 Author Report Share Posted November 28, 2019 I feel accomplished. Alright I tried to get the front cover on but the pan needs to come down just a little more. I lost some bolts I don’t know where they went all my bolts are in magnetic dishes. Same with the 10mm 1 Quote Link to post
banzai510(hainz) 4,717 Posted November 28, 2019 Report Share Posted November 28, 2019 Needs to come down more than you think as you add space of gasket.Dont tear it as it will be a leaker. I would use rtv in the corners with that gasket section you use.but this is me others might have a better Way 1 Quote Link to post
Scrapson 23 Posted November 28, 2019 Author Report Share Posted November 28, 2019 I thought RTV would be a better option. So close yet so far. Alright I’ll drop it a little more than I’d think 1 Quote Link to post
Stoffregen Motorsports 5,428 Posted November 29, 2019 Report Share Posted November 29, 2019 Hopefully you didn't lose them down the oil pan. 1 Quote Link to post
Scrapson 23 Posted November 30, 2019 Author Report Share Posted November 30, 2019 I found them in my cab not sure how they got there. 1 Quote Link to post
Scrapson 23 Posted December 1, 2019 Author Report Share Posted December 1, 2019 Started right up and ran like garbage. Adjusted the valves ran another compression test and it was 210 all the way across the board no oil but that was stellar compression as far as I was concerned. Timing is good it’s at 10° of advance but just runs like garbage makes an awful clopping noise like your dog drinking water ya know? I think the carb is messed up and we tried adjusting it but just won’t run right. I’m running out of ideas here. Quote Link to post
banzai510(hainz) 4,717 Posted December 1, 2019 Report Share Posted December 1, 2019 1342 counter clockwise fire order does distributor have a lot of slop? pull a plug wire and see if it changes or stays the same. Quote Link to post
Scrapson 23 Posted December 1, 2019 Author Report Share Posted December 1, 2019 The distributor does have a little play but it just changes from the 11:20 position to the 11:25 position with the amount it can wiggle. I’m not how much is too much on that. We got them in the correct firing order and sitting for 15 minutes trying to figure out the orientation. Quote Link to post
banzai510(hainz) 4,717 Posted December 1, 2019 Report Share Posted December 1, 2019 Well I don’t know what more to tell you. If me I would swap out a distributor and or carb swap since I have spares. i don’t know if you could dump some gas thru the carb and see if it runs smoother Quote Link to post
Scrapson 23 Posted December 1, 2019 Author Report Share Posted December 1, 2019 Two things one break clean is cheap ether besides the chlorinated don’t buy it as ether. I’ll have a local mechanic take a gander at it. I have Weber 32/36 that’s pretty shit clapped but I mean it never had a problem before Quote Link to post
Scrapson 23 Posted December 1, 2019 Author Report Share Posted December 1, 2019 I should mention the distributor shocked the living shit out of my friend when it was running we were going to put the vacuum advance line on and he touched the plastic cap and he just turned pale for about a minute so maybe the distributor is going out? I read on different forums just to replace the distributor so im going to reset the carbs adjustments ill just take it out 2 turns on the air fuel adjustment and the idle screw a turn just to see if it'll awaken from its shallow grave. Quote Link to post
datzenmike 38,453 Posted December 1, 2019 Report Share Posted December 1, 2019 If he got a shock this says the distributor cap or the wires are letting voltage leak out. Voltage will ALWAYS look for the shortest path to ground so make sure the cap rotor and wires are in good shape so that the shortest path is across the spark plug gap. I use dielectric grease on my nipples too. 1 Quote Link to post
Stoffregen Motorsports 5,428 Posted December 1, 2019 Report Share Posted December 1, 2019 16 hours ago, Scrapson said: ...runs like garbage makes an awful clopping noise like your dog drinking water ya know? 1 hour ago, Scrapson said: I should mention the distributor shocked the living shit out of my friend when it was running we were going to put the vacuum advance line on and he touched the plastic cap and he just turned pale for about a minute... That could be a symptom and a cause. A bad wire or a cracked cap or other similar problem with the high voltage produced by the ignition could make a noise like you describe, and could cause it to run like crap too. Quote Link to post
G-Duax 1,251 Posted December 1, 2019 Report Share Posted December 1, 2019 1 hour ago, Scrapson said: I should mention the distributor shocked the living shit out of my friend At least you did it right....... Never, ever diagnose possible ignition issues by touching them yourself, always have a friend (male or female) do it for you. "Honey, can you please hold this wire while I try to start this". 1 Quote Link to post
Scrapson 23 Posted December 1, 2019 Author Report Share Posted December 1, 2019 So just took it around the block the noise it makes is pretty bad almost reminds me of a Harley Davidson. It spewed oil out of somewhere I think it’s just the valve cover. It will not idle at all stop signs are my enemy Quote Link to post
banzai510(hainz) 4,717 Posted December 2, 2019 Report Share Posted December 2, 2019 Oil commons out. Yeah well see where from. seeing a for sale sign soon ck to see plug wires are somewhat good.Installed deep in the dist capI have been shocked before also.Doenst mean the wires are bad.one can check it at night and see if it’s bad ,you’ll see sparks or arching Quote Link to post
Scrapson 23 Posted December 2, 2019 Author Report Share Posted December 2, 2019 Check for spark on all cylinders cylinder 3&4 have none I’ll replace the plugs they look like they’ve had a lot of miles then after that if it doesn’t fix it I’ll do a cap. I had the local mechanic take a gander at it he said change the plugs. It felt good to drive it around the block I missed it. Quote Link to post
datzenmike 38,453 Posted December 2, 2019 Report Share Posted December 2, 2019 Remember that a spark will seek out the easiest path to ground. This could be the thin coating of carbon on the plug tip. Once clean, check again. Naturally you can't see what's going on inside when air is compressed by the piston.... and don't forget that your friend did get a shock. Quote Link to post
Scrapson 23 Posted December 2, 2019 Author Report Share Posted December 2, 2019 Well I can clean them off again but they do need to be replaced I would think I’ve put 3,000 miles on them and who knows how many before. I got some of the strangest looks and I made my coworkers day by driving by I don’t think I’m selling it soon. Side note same guy that got shocked to shit Quote Link to post
datzenmike 38,453 Posted December 2, 2019 Report Share Posted December 2, 2019 Have you ever replaced the rotor, cap and the plug wires????? Quote Link to post
Scrapson 23 Posted December 2, 2019 Author Report Share Posted December 2, 2019 The plug wires are new the rotor I’m not sure when it was replaced but the cap is new Quote Link to post
