Lonewolf1990 Posted November 8, 2019 Report Share Posted November 8, 2019 Alright ratsun fam, my alternator Bottom mount just snapped yesterday and I’m looking to replace ASAP , is there any universal one or what other car mount would work for me? Cause I’m heading to the junk yard Quote Link to comment
Stoffregen Motorsports Posted November 9, 2019 Report Share Posted November 9, 2019 The mount broke? Or the bolt that goes into it? Is it cast iron or formed steel? Quote Link to comment
Stoffregen Motorsports Posted November 9, 2019 Report Share Posted November 9, 2019 If the bolt broke, an old trick is to drill it out from one end to the other (so the bolt goes clear through) and use an L series head bolt (or other 10mm bolt). You will need to drill out the alternator lower bolt holes too. Broken lower alternator mounting bolts are common. Quote Link to comment
datzenmike Posted November 9, 2019 Report Share Posted November 9, 2019 The mount between alternator and the block would commonly snap mounting bolts because there were only 2 on the L16/18. The L20B was re-designed and has three larger ones. Quote Link to comment
Lonewolf1990 Posted November 9, 2019 Author Report Share Posted November 9, 2019 24 minutes ago, Stoffregen Motorsports said: The mount broke? Or the bolt that goes into it? Is it cast iron or formed steel? The mount , cast iron. 1 Quote Link to comment
datzenmike Posted November 9, 2019 Report Share Posted November 9, 2019 Take your old one with you. 1 Quote Link to comment
Lonewolf1990 Posted November 9, 2019 Author Report Share Posted November 9, 2019 Mine is the L20b , and it’s the top mount in the pic Quote Link to comment
Lonewolf1990 Posted November 9, 2019 Author Report Share Posted November 9, 2019 Can I use a mount from a d21? Quote Link to comment
datzenmike Posted November 9, 2019 Report Share Posted November 9, 2019 .... maybe. My info shows the Datsun cars and Z series truck mounts are the same but 620 truck are not. The L18 and all L20Bs used only in the 620 and the first year (1980) 720 truck were the same. In my picture you can see they are slightly different. The top one mounts the alternator higher than the bottom one by 3/4"? You could try one but clearance between the 620 alternator and the idler arm below it is very close. A lower mounted alternator would not be good. Quote Link to comment
Stoffregen Motorsports Posted November 10, 2019 Report Share Posted November 10, 2019 Hard to believe the bracket broke. I wonder what caused that to happen. Quote Link to comment
datzenmike Posted November 10, 2019 Report Share Posted November 10, 2019 Indeed, wouldn't the alternator 'ears' snap off? Loose fit alternator and over tightening. Isn't there a spacer used on the top one?? 1 Quote Link to comment
Lonewolf1990 Posted November 10, 2019 Author Report Share Posted November 10, 2019 My alternator fine , it’s the mount Quote Link to comment
datzenmike Posted November 10, 2019 Report Share Posted November 10, 2019 Can you post a picture of the mount? Quote Link to comment
