Need Help Finding B210 Axle Bearing
DIY 1985
Hello,
I'm looking for a bearing that supposedly is used on a '74 to '82 Datsun B210 axle, but I need it for a transfer case swap for a Land Cruiser, so I'm unable to measure an old one.  It is supposed to be a BCA PN RW1148.  Its dimensions are 32mm x 72mm x 20mm.  Rockauto describes a Centric with a 19mm width, so I wonder if my somewhat dated lead is kind of innacurate?  Could anyone confirm the accuracy of my lead, and could anyone find a source for the BCA, or a 20mm thick, bearing?
  • Replies 3
Used on the 510, 1200, B210, 210, B-310, 610/710/810, 200sx, A10, Maxima,Hardbody, Pathfinder, Xterra.
On the 2000- Xterra it's in the front differential and called the side shaft bearing. Only used on the right side. Very common and may be being used today.
