Lozer Posted October 19, 2019 Report Share Posted October 19, 2019 On Ebay. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F293053273140 Quote Link to comment
datzenmike Posted October 19, 2019 Report Share Posted October 19, 2019 Curious what it weighs compared to stock.. Quote Link to comment
john510 Posted October 19, 2019 Report Share Posted October 19, 2019 Probably not much lighter than a steel hood.I made a fiberglass hood and front fenders in high school.If you made them to have any strength they were pretty heavy and fit like shit. Quote Link to comment
datzenmike Posted October 19, 2019 Report Share Posted October 19, 2019 But they don't rust and probably take light hits without wrinkles. If you don't have a 510 hood then better than nothing. 2 Quote Link to comment
thisismatt Posted October 20, 2019 Report Share Posted October 20, 2019 5 hours ago, john510 said: Probably not much lighter than a steel hood.I made a fiberglass hood and front fenders in high school.If you made them to have any strength they were pretty heavy and fit like shit. You vacuum molded fiberglass in high school? Quote Link to comment
datzenmike Posted October 20, 2019 Report Share Posted October 20, 2019 Shit, all I did was paper mache. 1 Quote Link to comment
john510 Posted October 20, 2019 Report Share Posted October 20, 2019 8 hours ago, thisismatt said: You vacuum molded fiberglass in high school? Not on the 510 hood and fenders.We used a chopper gun for that.We did do vacuum bagging of other things though.Plastics class,i took it for two years.We made all kinds of cool stuff.Surfboards,kayaks,canoes,car parts even bongs from acrylic.Vocational/technical class instead of college prep courses. Quote Link to comment
thisismatt Posted October 20, 2019 Report Share Posted October 20, 2019 1 hour ago, john510 said: Not on the 510 hood and fenders.We used a chopper gun for that.We did do vacuum bagging of other things though.Plastics class,i took it for two years.We made all kinds of cool stuff.Surfboards,kayaks,canoes,car parts even bongs from acrylic.Vocational/technical class instead of college prep courses. I would think that a commercially made fiberglass body panel would be vacuum molded, otherwise yes it's going to weigh a ton Quote Link to comment
paradime Posted October 20, 2019 Report Share Posted October 20, 2019 (edited) I have one of the FG hoods that Troy sells for the same price and looks about the same as the one on eBay. Check out shipping & handling cost through. Troy's S&H was stupid expensive, but mine was coved by Auto Transport who damaged the old FB hood on my 510 while freighting it to my brother in Ashland. New one is pretty damn light, much lighter than steel. Not sure if its vacuum molded as there's an even weave texture on the backside. Rigid and well supported with a fiberglass support frame. Not a perfect fit buy any stretch but reshaping and gluing the skin back on the frame it straightened up nice. The top glaze was pretty rough and needed filling before painting, but thats to be expected. Edited October 20, 2019 by paradime Quote Link to comment
banzai510(hainz) Posted October 21, 2019 Report Share Posted October 21, 2019 paradime weill you made your look good your FG hood. Be honest the ebay one looks the same as Troys. Maybe he gets it from the same pace. Paradime key is does this shake at high speeds as underair can cause the hood to vibrate bad 1 Quote Link to comment
paradime Posted October 22, 2019 Report Share Posted October 22, 2019 Picts tell the whole story. I leave the is or isn't the same for you to decide. Does this FG hood shake at speed? No not on my car, but take a closer look. As long as the skin is well bonded to the support frame, and you use a front scoop to reduce pressure under the car, with adjustable rubber stabilizers on the leading edge, and two rubber wedge supports on both sides you're FG hood is good to go, at least to 135mph anyway. Beyond that everything shakes on a 510. Hope this was helpful. Quote Link to comment
thisismatt Posted October 22, 2019 Report Share Posted October 22, 2019 One thing to consider, if you haven't already, is I don't think you can mount the chrome strip to the leading edge on the FG hoods Quote Link to comment
paradime Posted October 22, 2019 Report Share Posted October 22, 2019 As far as I know, there is no FG or CF hood where you can just screw on the stock trim, but any hood can be modified for mounting it. It's just a matter of how much. The stainless trim around the headlight bezels mount on the same plain as the hood trim. Although this particular hood does not have holes on the bottom for mounting it, the leading and bottom edges are on proper plains and the front lip is the right thickness. While shiny trim isn't my thing, simply adding mounting holes is an easy enough mod to get'er done. Quote Link to comment
banzai510(hainz) Posted October 22, 2019 Report Share Posted October 22, 2019 Paradime well it looks awesome!!!! 1 Quote Link to comment
