Rephil Posted October 14, 2019 Report Share Posted October 14, 2019 I just acquired a ‘67 520 With a bad engine (it overheated, I’ll check it out). I’m wondering if anyone has chassis swapped with a 4x4? I was looking at an exterra frame at my local junkyard. Thoughts? Quote Link to comment
datzenmike Posted October 14, 2019 Report Share Posted October 14, 2019 The wheels and tires will stick out too far. The 620 is wider, 720 even wider and the D-21 Hardbody wider still. Get a tape measure and compare the 521 to the Xterra. You want to also compare the wheelbase or distance between the front and rear tires. If they are not a close match the wheels won't fit the 521 wheel wells. Quote Link to comment
hobospyder Posted October 14, 2019 Report Share Posted October 14, 2019 Do it, make it a wide body or widen the body while you're doing it. Anything is possible with enough time money and skills Quote Link to comment
wayno Posted October 14, 2019 Report Share Posted October 14, 2019 (edited) I put a 1966 Datsun 520 cab onto a 1980 Datsun 720 4wd frame/chassis, but I changed my mind and switched it over to a 1986 Nissan 720 2wd frame/chassis. Here it is on the 1980 4X4 frame/chassis. I had to do a body lift to clear the transfer case. Edited October 14, 2019 by wayno 1 Quote Link to comment
Rephil Posted October 14, 2019 Author Report Share Posted October 14, 2019 That looks pretty awesome! Quote Link to comment
Rephil Posted October 14, 2019 Author Report Share Posted October 14, 2019 5 hours ago, hobospyder said: Do it, make it a wide body or widen the body while you're doing it. Anything is possible with enough time money and skills I think it would look good with the wide body. I have some thinking to do! 1 Quote Link to comment
Rephil Posted October 14, 2019 Author Report Share Posted October 14, 2019 7 hours ago, datzenmike said: The wheels and tires will stick out too far. The 620 is wider, 720 even wider and the D-21 Hardbody wider still. Get a tape measure and compare the 521 to the Xterra. You want to also compare the wheelbase or distance between the front and rear tires. If they are not a close match the wheels won't fit the 521 wheel wells. So, I only measured the wheel base and not the width. Didn’t even occur to me the width. I better check that out. Thanks! Quote Link to comment
hobospyder Posted October 14, 2019 Report Share Posted October 14, 2019 20 minutes ago, Rephil said: I think it would look good with the wide body. I have some thinking to do! Dont think just do Or save some money and then do. 1 Quote Link to comment
hobospyder Posted October 14, 2019 Report Share Posted October 14, 2019 And make sure you share video or pictures and document the whole process. Quote Link to comment
nl320what Posted October 14, 2019 Report Share Posted October 14, 2019 Think of how to get it back on the road safely, fast, and cheaper. Best to stay away from something needing a new extensive ECU rewire and tune. Similar Toyota trucks match the wheel base and backspacing with 6 lug axles for 4x4 versions. Otherwise wait for a 620 4x4 factory conversion to pop up, or a 720 4x4 for simplicity. Only way to find out is to drop the body on the donor drivetrain and cut/weld to fit. Quote Link to comment
Rephil Posted October 14, 2019 Author Report Share Posted October 14, 2019 Yeah, our local junkyard doesn’t have any Datsun and not many nissans. I’ll figure this out 😜 Quote Link to comment
BrothersGarage Posted October 14, 2019 Report Share Posted October 14, 2019 17 hours ago, wayno said: I put a 1966 Datsun 520 cab onto a 1980 Datsun 720 4wd frame/chassis, but I changed my mind and switched it over to a 1986 Nissan 720 2wd frame/chassis. Here it is on the 1980 4X4 frame/chassis. I had to do a body lift to clear the transfer case. Oooof course you did. Jesus, is there anything you haven't created with a Datsun truck :D? 2 Quote Link to comment
nl320what Posted October 22, 2019 Report Share Posted October 22, 2019 Any progress on the truck? Another idea is the short wheelbase of the International Scout late 70s-80s to swap under. Quote Link to comment
Rephil Posted October 22, 2019 Author Report Share Posted October 22, 2019 Heck no.... I’m not sure what to do yet. It’s just sitting there lol. I picked up a 411 and the engine was in the seat and trunk so I’ve been messing with that. Quote Link to comment
Rephil Posted October 24, 2019 Author Report Share Posted October 24, 2019 So, I just located a cj6 frame. Looks like that might be the way to go. Quote Link to comment
mike Posted October 24, 2019 Report Share Posted October 24, 2019 Have you looked into samurai axles? Theyre not as strong as toyota but theyll take some abuse, theres decent aftermarket support and if youre not in a hurry you can find them on wheeling forums already built/upgraded cheaper than a stock set of yota axles that need rebuilt. Use your stock frame and start measuring... most of the time its way easier to fabricate suspension mounts on a stock frame than mess around with all the extra little stuff youd have to do with a frame swap, easier to license too. I had a hairbrained idea to build a 4x4 510 wagon... Sami axles, trans and transfer case and a 1.9 vw tdi. Leafs out back and a 3 link up front. Quote Link to comment
Rephil Posted October 24, 2019 Author Report Share Posted October 24, 2019 15 minutes ago, mike said: Have you looked into samurai axles? Theyre not as strong as toyota but theyll take some abuse, theres decent aftermarket support and if youre not in a hurry you can find them on wheeling forums already built/upgraded cheaper than a stock set of yota axles that need rebuilt. Use your stock frame and start measuring... most of the time its way easier to fabricate suspension mounts on a stock frame than mess around with all the extra little stuff youd have to do with a frame swap, easier to license too. I had a hairbrained idea to build a 4x4 510 wagon... Sami axles, trans and transfer case and a 1.9 vw tdi. Leafs out back and a 3 link up front. That sounds like a pretty good idea. I’ll look around for some axles. Thanks! Quote Link to comment
mike Posted October 25, 2019 Report Share Posted October 25, 2019 Ha ha, no problem, take lots of pics. When youre looking for the sami axles, deeper gears arent necessarily a selling point. The higher numerical gears have more meat on the pinion and you can get your gear reduction through the transfer case(s). Quote Link to comment
Master-O-Turbonics Posted October 29, 2019 Report Share Posted October 29, 2019 I did it once. Wish I would have finished it as it was but I got stupid with the project and undid all this lol. 71 521 on an 81 720 4x4 using the 4x4 body mounts that are essentially a body lift compared to a 521. only thing I changed on the rear suspension was I went to 2x4 leaf springs which is like 1.5" of lift. size comparison Quote Link to comment
Rephil Posted October 29, 2019 Author Report Share Posted October 29, 2019 8 minutes ago, Master-O-Turbonics said: I did it once. Wish I would have finished it as it was but I got stupid with the project and undid all this lol. 71 521 on an 81 720 4x4 using the 4x4 body mounts that are essentially a body lift compared to a 521. only thing I changed on the rear suspension was I went to 2x4 leaf springs which is like 1.5" of lift. size comparison So, I just located a cj6 frame. Looks like that might be the way to go. 9 minutes ago, Master-O-Turbonics said: I did it once. Wish I would have finished it as it was but I got stupid with the project and undid all this lol. 71 521 on an 81 720 4x4 using the 4x4 body mounts that are essentially a body lift compared to a 521. only thing I changed on the rear suspension was I went to 2x4 leaf springs which is like 1.5" of lift. size comparison That’s freaking awesome! Quote Link to comment
Master-O-Turbonics Posted October 29, 2019 Report Share Posted October 29, 2019 I would recommend going with a 720 4x4 chassis. Makes the project much easier plus its all proportional. the mounts at the radiator support bolt up and with a little work the 4 cab mounts can be made to work. 😞 1 Quote Link to comment
