Suki68 Posted October 8, 2019 Report Share Posted October 8, 2019 I’m new to this site and I know this question has been asked a 1000 times already, but I’ll ask anyway. My son recently got a 68 520 and the throttle cable is bad. Will a earlier 620 throttle cable work? It’s a screw in the firewall style. 1 Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 The 620 one has two small bolts. I suppose you could use two self tapping screws. Worth a try. By "bad" do you mean melted and stuck? This is from a missing ground wire from the engine to the sheet metal of the body. All power will go down the throttle cable and heat it up. A foot of 12 gauge wire to a screw on the firewall and to a valve cover bolt will do. 1 Quote Link to comment
DanielC Posted October 8, 2019 Report Share Posted October 8, 2019 620 throttle cables will not work. 520, and 521 trucks use imperial (inch) on the body, and fasteners. 620 trucks are all metric. 1 Quote Link to comment
Suki68 Posted October 8, 2019 Author Report Share Posted October 8, 2019 I’ve run new cable through the center of the throttle sheath. That sheath keeps cutting the cable, so I need all new I guess. 1 Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 I think the 620 cable is worth trying. 1 Quote Link to comment
Suki68 Posted October 8, 2019 Author Report Share Posted October 8, 2019 Thanks guys 1 Quote Link to comment
banzai510(hainz) Posted December 9, 2019 Report Share Posted December 9, 2019 (edited) Rockauto.com has a521 cable listed I have one but not installed. Look in the interior o or section I think Will list a Speedo cable also Edited December 10, 2019 by banzai510(hainz) 1 Quote Link to comment
Charlie69 Posted December 10, 2019 Report Share Posted December 10, 2019 620 cable is different. Quote Link to comment
420n620 Posted December 10, 2019 Report Share Posted December 10, 2019 got a 520 throttle cable in very good condition. PM me if your still looking. 1 Quote Link to comment
wayno Posted December 10, 2019 Report Share Posted December 10, 2019 3 hours ago, 420n620 said: got a 520 throttle cable in very good condition. PM me if your still looking. If this guy doesn't want it I would likely buy it if it will fit my 1966 520, right now I am using a 521 cable and the screw on mount part that holds the cable on the firewall is too small, mine is the same size as the 320. 1 Quote Link to comment
420n620 Posted December 11, 2019 Report Share Posted December 11, 2019 17 hours ago, wayno said: If this guy doesn't want it I would likely buy it if it will fit my 1966 520, right now I am using a 521 cable and the screw on mount part that holds the cable on the firewall is too small, mine is the same size as the 320. Siki68 hasn't been back on since October so his lost. Besides that, every ones money spends and looks the same. I no longer have a photo host, don't want one either so no pic's. It's from a 68 520, screws to a firewall bracket which is included w/ clip, the carb end goes into a carb bracket where you adjust the slack out of the cable. If you want a pic, I'll PM you my email address. More details in the PM. 1 Quote Link to comment
Suki68 Posted March 10, 2020 Author Report Share Posted March 10, 2020 Sorry guys, I found a new throttle housing. I went to the salvage yard and made my own throttle cable 1 Quote Link to comment
