TimmyG Posted October 7, 2019 Report Share Posted October 7, 2019 Unless someone knows how I can get my hands on the OEM formed fuel hoses (tank to filter, filter to pump, pump to hard line)... I'm gonna have to use an inline fuel filter and use bulk fuel hose. Is there any particular flow rate or size filter I should look for? Or any generic inline fuel filter will do? Thanks. 1 Quote Link to comment
Crytek89 Posted October 7, 2019 Report Share Posted October 7, 2019 Single in-single out.https://www.rockauto.com/en/moreinfo.php?pk=478690&cc=1210329&jsn=891 Part number i'm familiar with is 71650, but it's just a standard filter. 1 Quote Link to comment
TimmyG Posted October 7, 2019 Author Report Share Posted October 7, 2019 59 minutes ago, Crytek89 said: Single in-single out.https://www.rockauto.com/en/moreinfo.php?pk=478690&cc=1210329&jsn=891 Part number i'm familiar with is 71650, but it's just a standard filter. Thanks. So you're using this generic type filter? Just wanna make sure I don't find myself in an "OOPS" situation when it comes to gasoline. 🤪👍🏻 1 Quote Link to comment
Charlie69 Posted October 8, 2019 Report Share Posted October 8, 2019 Remember TimmyG you have a rusty tank so it is best to be able to see into the filter. Quote Link to comment
TimmyG Posted October 8, 2019 Author Report Share Posted October 8, 2019 1 hour ago, Charlie69 said: Remember TimmyG you have a rusty tank so it is best to be able to see into the filter. Good idea. I am installing a donor tank from my parts truck. That truck actually has much less rust on the frame, so hoping the tank is better. It's not dented so that's a plus! Ha 1 Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 6 hours ago, Crytek89 said: Single in-single out.https://www.rockauto.com/en/moreinfo.php?pk=478690&cc=1210329&jsn=891 Part number i'm familiar with is 71650, but it's just a standard filter. This looks like a fuel injection filter. OR they are just using a generic picture. All carb filters I've seen are under $5 and clear plastic. I think I have one from a Honda on my L20B. Looks exactly the same as the Nissan one. 2 Quote Link to comment
TimmyG Posted October 8, 2019 Author Report Share Posted October 8, 2019 I will have to check the hose inside diameter and then just pick up another one like what I added under the hood I guess. 1 Quote Link to comment
thisismatt Posted October 8, 2019 Report Share Posted October 8, 2019 If you are getting large particles, then one of the cleanable glass body, metal mesh filters in line before a finer sealed filter can be a good idea. 2 Quote Link to comment
Crytek89 Posted October 10, 2019 Report Share Posted October 10, 2019 On 10/7/2019 at 8:06 PM, datzenmike said: This looks like a fuel injection filter. OR they are just using a generic picture. All carb filters I've seen are under $5 and clear plastic. I think I have one from a Honda on my L20B. Looks exactly the same as the Nissan one. I think it's just a generic photo - the others on Rockauto are showing as the plastic ones you mentioned. 1 Quote Link to comment
