Madkaw Posted July 13, 2021 Author Report Share Posted July 13, 2021 2 hours ago, bottomwatcher said: Definitely fwd on mine. The shifter comes out of the top of the trans on the C not the end like the B. Wow - that’s weird . I measure it all out and even with shifter top mounted it is still further back than the B 1 Quote Link to comment
datzenmike Posted July 13, 2021 Report Share Posted July 13, 2021 Around 30". 1 Quote Link to comment
bottomwatcher Posted July 14, 2021 Report Share Posted July 14, 2021 7 hours ago, Madkaw said: Thanks . So that pic is looking from the rear to front ? Yes. Not easy to take a pic of but that is how I mounted it. Been working fine about 18 years now. On the other hand after driving it today no issues I parked it in the shop and after a few minutes a radiator hose blew its gizzard and pissed a gallon of coolant on the floor. Always something. 1 Quote Link to comment
datzenmike Posted July 14, 2021 Report Share Posted July 14, 2021 Rad hoses rot from the inside out, you can't tell by looking at them. Give them a squeeze every year. When they go soft it's time. If replacing a rad hose slit lengthwise with carpet knife and peel off the rad spout. This will save reefing on it and breaking the solder seal. 1 Quote Link to comment
Madkaw Posted April 8 Author Report Share Posted April 8 Another question regarding this swap . When I put the bell housing plate( between the engine and trans ) up to the 71c trans it doesn’t cover the bell housing at the bottom . I have an extra plate that I believe came off a z24 to compare , but maybe it’s not . The 4 bolt holes for bell housing match up - but that’s it . Quote Link to comment
datzenmike Posted April 8 Report Share Posted April 8 Have you tried flipping over to the other side to see if the holes line up better? Called the engine plate. It just keeps debris from entering against the spinning flywheel at the front bottom. Automatics have a hole so you can get at the torque converter mounting bolts to the flex plate. Must have it on or the starter will travel too far inward for engagement. Not that critical as long as all engine/transmission and starter bolts fit through. There should be a hollow alignment dowel on the lower left side of block that the transmission mounting bolt goes through Quote Link to comment
Madkaw Posted April 8 Author Report Share Posted April 8 I flipped the engine plate and that makes it worse . Must be some difference in the 71C engine plate Quote Link to comment
bottomwatcher Posted April 8 Report Share Posted April 8 (edited) That's not right. I used my z 24 plate. Plus it needs to be behind the flywheel. I went to put the trans on once and had forgotten. Dumbass me! Edited April 8 by bottomwatcher Spelling Quote Link to comment
Madkaw Posted April 8 Author Report Share Posted April 8 2 hours ago, bottomwatcher said: That's not right. I used my z 24 plate. Plus it needs to be behind the flywheel. I went to put the trans on once and had forgotten. Dumbass me! Not sure what else this plate could have come from . Only have worked on L6’s and Z24s Quote Link to comment
Madkaw Posted April 8 Author Report Share Posted April 8 Anyone have a z24 plate to compare ? Quote Link to comment
datzenmike Posted April 8 Report Share Posted April 8 Take a better picture with the transmission upright as it would be in the truck and shoot it from the front. Quote Link to comment
Madkaw Posted April 8 Author Report Share Posted April 8 2 hours ago, datzenmike said: Take a better picture with the transmission upright as it would be in the truck and shoot it from the front. I mean it’s kind of sitting that way now . What can’t you see? Quote Link to comment
datzenmike Posted April 8 Report Share Posted April 8 Transmission may be sitting upright but the picture is shooting down. I can only see downward to the bottom. It's upside down. The top of the transmission is somewhere to the right. Quote Link to comment
bottomwatcher Posted April 8 Report Share Posted April 8 Show the whole thing and I am nowhere near my datsun and haven't seen it in 6 months but from my unreliable memory. The bottom of the plate in that picture looks like the top of the trans. Also the 2wd and 4wd were different but interchangeable. I know I am running my original z 22 plate from 1982 on my KAe and C trans. Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 This is sitting straight up . Do I have a KA trans ? Quote Link to comment
bottomwatcher Posted April 9 Report Share Posted April 9 2 hours ago, Madkaw said: This is sitting straight up . Do I have a KA trans ? Sure looks like it. Where did it come from? I bought a used jdm B series years ago and the bellhousing was wierd and unusable had to swap my original. But unless it is clocked wierd that looks right to me. The 30A is more rounded. Sorry I can't be more help. Wont see my parts pile until the end of the month. Mike will have something. Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 I was using the engine plate to transfer bolt pattern from the block I have sitting on the garage . Might actually be worth the effort to try and bolt it too that block to see how it sits( clocked) . Quote Link to comment
datzenmike Posted April 9 Report Share Posted April 9 Here is an '85 or 6, Z series front case.... Had to turn the picture to match, fuck me how hard is t to take a picture the right side up???????? Need the engine plate. I think the engine plate is from an L series or something Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 15 minutes ago, datzenmike said: Is it me or is this picture showing on it's side with bottom to the left?????? Need the engine plate on now. I don’t know why the pic is sideways . Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 (edited) They look the same except an extra hole at 3 -O clock . This plate might be off a diesel L6 I had at one time Edited April 9 by Madkaw Quote Link to comment
datzenmike Posted April 9 Report Share Posted April 9 Could be my web browser? My take is they are basically the same. What about the engine plate??? Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 9 minutes ago, datzenmike said: Could be my web browser? My take is they are basically the same. What about the engine plate??? Well - I should have put the plate against there , but stood the trans upright again on the furniture mover . So I take it again - ugh. Quote Link to comment
Madkaw Posted April 9 Author Report Share Posted April 9 3 hours ago, datzenmike said: Could be my web browser? My take is they are basically the same. What about the engine plate??? Well - I should have put the plate against there , but stood the trans upright again on the furniture mover . So I take it again - ugh. Quote Link to comment
NC85ST Posted April 10 Report Share Posted April 10 Sorry, but the top of that transmission does not look right. There should be two bolt holes at the top. That’s a z24. Quote Link to comment
