LS_Wagon Posted September 25, 2019 Report Share Posted September 25, 2019 Hi All, Datsun Noob here. I noticed my rear passenger side wheel would not spin when I lifted the car to have a look underneath. I had a hard time removing the drum and as you can see from the pic, I need to replace the cylinder. I took the driver side drum off and did not see the same problem. My question is, should both shoes move outwards when I press the brake pedal or just trailing shoe marked with the green arrow? In both sides we only have the one with green arrow move out and return while the other is stationary. Thanks for the help, Luis. Quote Link to comment
datzenmike Posted September 25, 2019 Report Share Posted September 25, 2019 The green one will probably begin moving after the red one contacts the inside of the drum and can't move further. Quote Link to comment
LS_Wagon Posted September 25, 2019 Author Report Share Posted September 25, 2019 19 minutes ago, datzenmike said: The green one will probably begin moving after the red one contacts the inside of the drum and can't move further. Thanks for the info Datzenmike! Going to order a replacement cylinder soon. Quote Link to comment
banzai510(hainz) Posted September 26, 2019 Report Share Posted September 26, 2019 (edited) Your might just need some cleaning. 510 drums one should drill a Jack screw hole I use the standard 8mm x1.25 I think it is. O rileys will have the correct drill bit and matching Tap. is that the paint getting hot and flaking? Edited September 26, 2019 by banzai510(hainz) Quote Link to comment
G-Duax Posted September 26, 2019 Report Share Posted September 26, 2019 Nope, leaking wheel cylinder. Brake fluid acts as paint remover......... Quick way to know what size tap drill you need for ANY metric screw is to subtract the pitch, from the bolt size. So 8mm minus 1.25mm = 6.75mm drill. And a lot of times drums come off hard because they are worn where the shoes contact them, and over the years people keep adjusting the brakes, so when you go to remove them, the shoes are sitting inside a larger diameter than the unworn area. I always adjust them down before I try to remove a drum, make life a lot simpler. Quote Link to comment
LS_Wagon Posted September 26, 2019 Author Report Share Posted September 26, 2019 4 hours ago, G-Duax said: Nope, leaking wheel cylinder. Brake fluid acts as paint remover......... Quick way to know what size tap drill you need for ANY metric screw is to subtract the pitch, from the bolt size. So 8mm minus 1.25mm = 6.75mm drill. And a lot of times drums come off hard because they are worn where the shoes contact them, and over the years people keep adjusting the brakes, so when you go to remove them, the shoes are sitting inside a larger diameter than the unworn area. I always adjust them down before I try to remove a drum, make life a lot simpler. Thank you all for the comments. Yes the brake shoe paint is bubbling off and confirms a leak. This was my first time dealing with drums and I didn’t know what way to turn the adjuster to shrink the shoe diameter but I understand the mechanism now. Can’t wait to drive this Wagon to work. Thanks again for the input. Quote Link to comment
