athoose Posted September 20, 2019 Report Share Posted September 20, 2019 Can anyone say what this weird clacking sound is. It comes and goes. I adjusted valves and that didn't help. Quote Link to comment
banzai510(hainz) Posted September 21, 2019 Report Share Posted September 21, 2019 See if chainguide loose alt mount loose valve mouse springs broken Quote Link to comment
datzenmike Posted September 21, 2019 Report Share Posted September 21, 2019 Try turning the adjustment screw inside under that rubber cap counter clockwise a turn or two. Keep track so you can return it to where it is now. See if that helps. Quote Link to comment
athoose Posted September 26, 2019 Author Report Share Posted September 26, 2019 On 9/20/2019 at 8:40 PM, banzai510(hainz) said: See if chainguide loose alt mount loose valve mouse springs broken Chain guide look good But found this This seems like it could cause clacking. Whatcha think? Also, it seems my cam is on position 3 but dash is to the left of v groove. Does this mean the cam is advanced retarded lol. What should my timing be around? I'll check into that thing on the carb, if this doesn't do it. Thanks Quote Link to comment
datzenmike Posted September 26, 2019 Report Share Posted September 26, 2019 The pump spring is fairly strong so it is tight against the pump eccentric.. Take the pump off and see if broken. If it looks OK likely everything is ok. Quote Link to comment
datzenmike Posted September 26, 2019 Report Share Posted September 26, 2019 2 hours ago, athoose said: Also, it seems my cam is on position 3 but dash is to the left of v groove. Does this mean the cam is advanced retarded lol. What should my timing be around? I If V is to right of, or under the line it's fine. Chain may have stretched or the head has been milled which will have the effect of lengthening the chain. Quote Link to comment
athoose Posted September 27, 2019 Author Report Share Posted September 27, 2019 Tested with non working fuel pump, still clacked until it ran out of gas. Better video Could this be exhaust leak? Sounds metallic to me, though. Mouse things on cam look fine. And adjusting screw on carb didn't seem to do anything. Quote Link to comment
Stoffregen Motorsports Posted September 28, 2019 Report Share Posted September 28, 2019 That sure sounds like a valve to me. Are you adjusting the valves at the tip of the rocker? .010"? It could be a sticking valve, or even a loose valve seat. How about a loose spark plug? Quote Link to comment
athoose Posted October 7, 2019 Author Report Share Posted October 7, 2019 Put 4 oz of seafoam in oil and sprayed the aerosol seafoam down the carb. Didn't work right away but by next morning it's silky smooth. Wow, that stuff works! Quote Link to comment
banzai510(hainz) Posted October 8, 2019 Report Share Posted October 8, 2019 I cant believe it!!!!!!! wonder if the valve seat got stuck back in its orginal position? be nice to know exactly what was the noise Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 Seafoam is snake oil. It's just petroleum distillates..... solvents. Over hyped, over priced snake oil. Uses by the unknowing and the desperate. If your engine is that gummed up change your oil and filter more often or get a better oil. Quote Link to comment
banzai510(hainz) Posted October 8, 2019 Report Share Posted October 8, 2019 (edited) 6 minutes ago, datzenmike said: If your engine is that gummed up change your oil and filter more often or get a better oil. that's what I was really thinking. But it worked Edited October 8, 2019 by banzai510(hainz) Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 Something sticky can come unstuck too. If stuck then why? Not enough oil changes? running engine without thermostat and too cold? Oil polluted with blow-by? A well maintained and tuned engine won't need that crap. Pour half a cup of diesel fuel in the oil for the same thing. Quote Link to comment
athoose Posted October 8, 2019 Author Report Share Posted October 8, 2019 3 hours ago, banzai510(hainz) said: I cant believe it!!!!!!! wonder if the valve seat got stuck back in its orginal position? be nice to know exactly what was the noise Yeah I'm curious too, something sticking is my guess, glad I opted to give seafoam a chance. I watched a YouTube video with similar results prior to trying it. Much prefer a couple bucks and ten minutes of my time to the alternatives. Quote Link to comment
athoose Posted October 8, 2019 Author Report Share Posted October 8, 2019 3 hours ago, datzenmike said: Seafoam is snake oil. It's just petroleum distillates..... solvents. Over hyped, over priced snake oil. Uses by the unknowing and the desperate. If your engine is that gummed up change your oil and filter more often or get a better oil. Is it snake oil if it works. I understand the hype and if some other product does the same thing for less that doesn't negate its effectiveness. Knew what I needed and seafoam delivered. Yes, I was seeking to stop a clacking in the engine. Could I have disassembled to engine and cleaned, checked, etc... Yes, but it seems likely something was sticking and this product freed it up. I'm think it's fair to say something caused it to stick. BTW, I'm in no way affiliated with seafoam. 1 Quote Link to comment
banzai510(hainz) Posted October 8, 2019 Report Share Posted October 8, 2019 (edited) But your a YOUTUBE Technician!!!! get your certified patch. well it helped and good for you. To me its just PBPlaster in a foam form(mix with Alkiseltzer) Edited October 8, 2019 by banzai510(hainz) Quote Link to comment
athoose Posted October 8, 2019 Author Report Share Posted October 8, 2019 17 minutes ago, banzai510(hainz) said: But your a YOUTUBE Technician!!!! get your certified patch. well it helped and good for you. To me its just PBPlaster in a foam form Should have told me that sooner. I keep a gallon of pbblaster and a brush at arms reach when wrenching. I actually used some on the valves a few days prior to seafoam, maybe it was the nectar of the gods that cured that clack, after all. Quote Link to comment
G-Duax Posted October 8, 2019 Report Share Posted October 8, 2019 Mike is right, SeaFoam is not anything special. Just about any fluid poured down the carb while it's running will destroy carbon build up. First learned about de-carbonizing an old engine while getting my Associates Degree, and being poor as shit. Bought an old Vega for $50, that the owner thought the engine was shot, because it had a bad hammering sound coming from that joke of an engine. Was about to pull the thing to go after bearings or broken pistons, when a friend suggested trying a 'Coke bottle tune-up'. He said to get the engine up to running temp, then pour a Coke bottle of water down thee carb, while manually holding the throttle open far enough to keep it running. I did, that piece of shit engine sent a billowing cloud of black smoke, and chunks of carbon out the tail pipe, and stopped hammering ! The issue wasn't worn out or broken parts, it was the carbon build up on the pistons, and head, that were making contact. Quote Link to comment
john510 Posted October 8, 2019 Report Share Posted October 8, 2019 4 hours ago, athoose said: Is it snake oil if it works. I understand the hype and if some other product does the same thing for less that doesn't negate its effectiveness. Knew what I needed and seafoam delivered. Yes, I was seeking to stop a clacking in the engine. Could I have disassembled to engine and cleaned, checked, etc... Yes, but it seems likely something was sticking and this product freed it up. I'm think it's fair to say something caused it to stick. BTW, I'm in no way affiliated with seafoam. Don't buy into everything Mike says.He oils K&N air filters with WD-40.The K&N filter oil is the same according to him.I've had good results using Seafoam as an injector cleaner.Do i think it will fix a shot engine ? No of course not.But it does have uses. Quote Link to comment
G-Duax Posted October 8, 2019 Report Share Posted October 8, 2019 Agreed on both Mike's view of the world, and advantages of 'snake oils'. I'm sure there are compounds in SeaFoam that help penetrate, and dissolve deposits, just not the only way to de-carbon an engine. Quote Link to comment
Stoffregen Motorsports Posted October 9, 2019 Report Share Posted October 9, 2019 On 10/8/2019 at 7:23 AM, datzenmike said: Seafoam is snake oil. It's just petroleum distillates..... solvents. Over hyped, over priced snake oil. Uses by the unknowing and the desperate. If your engine is that gummed up change your oil and filter more often or get a better oil. That's like saying Bisquick is snake oil. It's nothing but flour, shortening, salt, and baking powder. Yes it is, but it's conveniently packaged to make the job easier. Quote Link to comment
banzai510(hainz) Posted October 9, 2019 Report Share Posted October 9, 2019 I had a pressure washer that wasn't working right I shot PB Blaster were the water comes out. a day later it worked then a year later I fucked up. A coworker said you want a pressure washer?. I said whats wrong. It don't pump. I told him I shot PB Blaster in there. He did and next day he said he wasn't giving me the pressure washer as it now works. Some body told me there is a valve that sticks and one needs to lube it up over the winter. So yes Seafoam/WD automatic trans fluidwith acetone most likely will work in certain places 1 Quote Link to comment
bottomwatcher Posted October 9, 2019 Report Share Posted October 9, 2019 I love seafoam! Works wonders on small outboards, mowers,chainsaws ect. Maybe snake oil to some but I have done the oil change flush arraignment, fuel stabilization ect. for me I am convinced. I did decarbon a motor using water in a vacuum line run into the cab, don't want to hydro lock but steam is a powerful cleaner Quote Link to comment
datzenmike Posted October 10, 2019 Report Share Posted October 10, 2019 Fill your reservoir with winter windshield washer fluid and run the hose into the carb throat. Go for a drive. Hammer it to 4K in third and push the button. The temp gauge will drop like a stone. Let it warm thoroughly and give er again. It's the sudden cooling (steam is the result) that cracks the deposits and they flake off. Not just carbon either, but that crusty almost ceramic looking deposit that's glazed on. Get the engine super hot when doing this. Quote Link to comment
athoose Posted October 18, 2019 Author Report Share Posted October 18, 2019 Well after a glorious clack free week, the clack came back with a vengeance. The lash cap came off the 3rd cyl intake. Chewed the retainer and banged around a little bit. This happened on this same valve like ten years ago when I first got the truck. This time putting the cap back doesn't work. It quickly comes off. I'm guessing the valve is sticking or it's bent, or the guide/valve stem is loose. So, I'm thinking I've got to take the head off and see what's going on with that valve. Ugh ... the cam looks fine but the rocker arm has a light score in it, I'm thinking I should replace the arm but are they matched to the cam at this point? Quote Link to comment
