TimmyG Posted September 15, 2019 Report Share Posted September 15, 2019 Can someone recommend a throttle linkage return spring kit for my Weber 32/36 on z24? Or should I just call Redline? Carb has no return spring setup on linkage. While it operates fine/idles fine, the gas pedal resistance is very light. Pedal being a little more firm would be nice. The pedal return spring is in place so that's not the issue. 1 Quote Link to comment
Charlie69 Posted September 15, 2019 Report Share Posted September 15, 2019 (edited) This is what I did. The bracket is of any carbureted GM car or truck. Edited September 15, 2019 by Charlie69 1 Quote Link to comment
TimmyG Posted September 15, 2019 Author Report Share Posted September 15, 2019 Awesome. Do you have a pic of the spring attached to the actual throttle linkage? It's just hooked on there or did yours have a hole for the spring? Mine doesn't. 1 Quote Link to comment
