pdp8 Posted September 15, 2019 Report Share Posted September 15, 2019 When I turn my headlight switch on, the headlights come on immediately but the parking and dash lights don't. The eventually do come on after a delay, the duration of which seem a little random but typically in the .5-1 minute realm. It's interesting since my previous wagon did exactly the same thing. Any ideas? Oh, and why isn't there a specific B310/210 division or even mention under "cars"? Quote Link to comment
datzenmike Posted September 15, 2019 Report Share Posted September 15, 2019 The B210 /B310 is here ... https://ratsun.net/forum/46-b210/ . OR.. https://ratsun.net/forum/13-1200/ ... The 1200 sunny (B110) is the forerunner of all the B cars. Parking light delay is more common than you think. It usually is the dried up grease mixed with years of dust on the headlight switch which, I think, is in the steering column. With the plastic 'clam shell' unscrewed and removed from the column, you should be able to use spray contact cleaner/lubricant to clean the switch contacts, without removing the steering wheel. If by chance the entire light/turn signal/wiper switch assy needs to come off the column, the steering wheel will need to be removed.. Quote Link to comment
pdp8 Posted September 20, 2019 Author Report Share Posted September 20, 2019 I just meant to point out that the 210 isn't mentioned "by name" in the intro to the B210 forum in the way the 610/710 is called out (B210/210 or B210/B310). Not a grease problem this time anyway. There was a tiny bit of grease on the plunger but it felt clean and moved easily. The contact for marker lights is normally closed and the switch pushes it open when off, a few decades of that and the spring contact took a very minor "set". That and a slight amount of burning on the contacts and I was having trouble. I managed to remove the contacts from the switch, bend the finger for the park lights very slightly, polish them (pencil eraser) then acetone and a touch of contact lubricant. In doing so I have achieved a measure of on-demand illumination, perhaps I can use this technique in other aspects of my life. 🙂 Thanks for the pointer. Quote Link to comment
