rosso Posted September 15, 2019 Report Share Posted September 15, 2019 I have been looking for a source of striped wire to start redoing the wiring on my VG33 510 project. Does anyone have a good source for wires that resemble the factory multi-colored stuff? What gauge wire is it all? Here is the closest I have found: https://www.sherco-auto.com/striped-tracer-wire.html Here is their Yellow/Black Any other good sources? Quote Link to comment
banzai510(hainz) Posted September 21, 2019 Report Share Posted September 21, 2019 Jeff would just yank out the wiring from a late model Nissan as a lot are consistent with the older datsuns 1 Quote Link to comment
4perrev Posted January 25, 2020 Report Share Posted January 25, 2020 You can Stripe any wire you want to any color. Buy the base colored wire, make a jig out of wood. Drill a hole so the wire will feed through. Drill a hole on the top or side large enough for a sharpie marker. Insert desired marked color and you can stripe anything you want, for as long as you want. Other than the cost of wire, the sharpie pack is cheap and you can reuse for any color combination you need! 1 Quote Link to comment
difrangia Posted January 25, 2020 Report Share Posted January 25, 2020 I had a super good experience with these folks when I was re-doing the engineroom loom on my 320: http://riwire.com/ 1 Quote Link to comment
rosso Posted January 25, 2020 Author Report Share Posted January 25, 2020 6 hours ago, difrangia said: I had a super good experience with these folks when I was re-doing the engineroom loom on my 320: http://riwire.com/ I checked out the website and the wire selection looks great! Thanks, I bookmarked the site so when I am ready to do the wiring I have the link handy. Quote Link to comment
rosso Posted January 25, 2020 Author Report Share Posted January 25, 2020 8 hours ago, 4perrev said: You can Stripe any wire you want to any color. Buy the base colored wire, make a jig out of wood. Drill a hole so the wire will feed through. Drill a hole on the top or side large enough for a sharpie marker. Insert desired marked color and you can stripe anything you want, for as long as you want. Other than the cost of wire, the sharpie pack is cheap and you can reuse for any color combination you need! Thanks for the idea - I can definitely see doing this for black stripes. Great find of your wagon in Port Townsend, I look forward to seeing your progress. My VG33 swap into my '72 wagon is going well and I like it more and more even though it's still in pieces, 1 Quote Link to comment
Icehouse Posted January 26, 2020 Report Share Posted January 26, 2020 On 9/20/2019 at 7:49 PM, banzai510(hainz) said: Jeff would just yank out the wiring from a late model Nissan as a lot are consistent with the older datsuns Yep! Did that for years. Just recently spent 500 bucks at Waytek and bought a bunch of 1,000 ft rolls. I bought all the common stripped wires needed in KA and SR swaps. Black with white stripe Black with Red stripe Black with yellow stripe Red with black stripe solid white Solid red Solid brown and a bunch more. Quote Link to comment
68Datsun510 Posted January 27, 2020 Report Share Posted January 27, 2020 On 9/15/2019 at 10:52 AM, rosso said: I have been looking for a source of striped wire to start redoing the wiring on my VG33 510 project. Does anyone have a good source for wires that resemble the factory multi-colored stuff? What gauge wire is it all? Here is the closest I have found: https://www.sherco-auto.com/striped-tracer-wire.html Here is their Yellow/Black Any other good sources? I dont have a solution for your wiring needs, but we have a growing community of VG swapped Datsuns on FB if you feel like joining. https://www.facebook.com/groups/1848877351796281/ Quote Link to comment
rosso Posted January 27, 2020 Author Report Share Posted January 27, 2020 6 hours ago, 68Datsun510 said: I dont have a solution for your wiring needs, but we have a growing community of VG swapped Datsuns on FB if you feel like joining. https://www.facebook.com/groups/1848877351796281/ Thanks, I am a member although I am not a Facebook fan so don't use it much. I will put it on my reading list. I am Michael in Port Angeles, Washington. Cheers 1 Quote Link to comment
68Datsun510 Posted January 28, 2020 Report Share Posted January 28, 2020 21 hours ago, rosso said: Thanks, I am a member although I am not a Facebook fan so don't use it much. I will put it on my reading list. I am Michael in Port Angeles, Washington. Cheers Awesome! I dont blame you, one of those things thats very useful, yet really wish it never came to be at the same time...on the bright side, they havent billed me for the 30,000+ pictures they host for me lol Quote Link to comment
rosso Posted March 4, 2020 Author Report Share Posted March 4, 2020 On 1/25/2020 at 5:21 AM, 4perrev said: You can Stripe any wire you want to any color. Buy the base colored wire, make a jig out of wood. Drill a hole so the wire will feed through. Drill a hole on the top or side large enough for a sharpie marker. Insert desired marked color and you can stripe anything you want, for as long as you want. Other than the cost of wire, the sharpie pack is cheap and you can reuse for any color combination you need! I just did this for the one wire I needed to connect the original 510 oil pressure sending wiring YB around to the other side where I have the new sender. And the dashboard oil warning light works. 🙂 Thanks, one more thing off the list. 1 Quote Link to comment
4perrev Posted March 5, 2020 Report Share Posted March 5, 2020 Sweet. Glad the trick worked for ya!! Quote Link to comment
