wayno Posted September 18, 2019 Report Share Posted September 18, 2019 I cannot say for sure the ethanol is the lower layer, but it is about 10 percent of the volume, and that truck would not run on that lower layer, the truck was lifted and the drain plug removed, we got it started with fresh gas. I have heard/read that once it separates the gas part doesn't have a high enough octane rating anymore, but that was a long time ago and I don't remember where I read that. Quote Link to comment
scooter Posted September 19, 2019 Report Share Posted September 19, 2019 if you dont mind changing a spark plug once in a while avgas is great in weedeaters and other small engines. The smell is wonderful! mike may actually have a better supply of fuel then what I get up here, its questionable here sometimes as theres been a few people that had safe tunes in their turbo cars just to have them break ring lands due to a shit batch of "94" octane. the 87 is junk too, sometimes you get batches that will make your shitbox ping like crazy and othertimes not. on my old boat I had a chrysler 45 on it, it never had carburator problems, but if i ran ethanol gas I ended up replacing the fuel lines annually. on the flip side of the coin, i am DYING for pump E85 here. we're so bass ackwards up here in canada ugh. that would change everything Quote Link to comment
Easygoingjc Posted September 22, 2019 Report Share Posted September 22, 2019 We used to put a colder heat range plug in sleds and motorcycles when ethanol blended fuel came into effect. It burns hotter causing increased cylinder temps. I remeber seeing this from our ngk rep. Quote Link to comment
datzenmike Posted September 22, 2019 Report Share Posted September 22, 2019 Yeah, forget Photobucket, it's blurred. Quote Link to comment
Easygoingjc Posted September 22, 2019 Report Share Posted September 22, 2019 15 minutes ago, datzenmike said: Yeah, forget Photobucket, it's blurred. Can't figure out why. even the photos are. The bulletin no. NGKSP-0506-3 Quote Link to comment
datzenmike Posted September 22, 2019 Report Share Posted September 22, 2019 Published in 2006???? This would be for engines running at or above stoichiometric (leaner) running EFI engines not 40 year old Datsuns with carburetors. I've noticed zero difference with the 10% ethanol, maybe less power but it's only theoretical and not really enough to notice in the seat of your pants. There is zero indication of being lean or over heating. My gap is about 0.040 for the EI ignition and it runs without miss. Plugs are light tan. Quote Link to comment
Easygoingjc Posted September 22, 2019 Report Share Posted September 22, 2019 I would agree with you mike. For the most part the difference is solved with a carb tune. The real problem we found was guys starting their engine and not letting it warm up. Then going for a blast and squeeking a piston. Thread related I would make sure the float is not stuck on the carb for that cylinder. Pull the plug on the bowl and see if fuel flows. Quote Link to comment
datzenmike Posted September 22, 2019 Report Share Posted September 22, 2019 You could also squirt Windex on the exhaust manifolds and compare how hot they are or 'shoot' with a borrowed IR gun. Quote Link to comment
frank88 Posted October 15, 2019 Author Report Share Posted October 15, 2019 Quick update, thank you to the first suggestions.... running on 4 now. Was blocked pilot jet. Cleaned them all, not sure how I forgot to do that when I refreshed the carbs. Had a confidence knock but back on it now! Cheers guys Quote Link to comment
datzenmike Posted October 16, 2019 Report Share Posted October 16, 2019 I noticed when the bowl covers are off that there is often a smudge of 'silt' that collects in the lowest part. I used a Q-tip. Quote Link to comment
frank88 Posted October 16, 2019 Author Report Share Posted October 16, 2019 Yea I cleaned that out. There is also a drain on each so i guess draining the bowls every now and again in situ could help Quote Link to comment
datzenmike Posted October 16, 2019 Report Share Posted October 16, 2019 Handy for draining any water that might collect. Not a problem here with 10% ethanol gas. Quote Link to comment
