banzai510(hainz) Posted September 10, 2019 Report Share Posted September 10, 2019 (edited) I usually don't need help but Im stumped right now on this one I changed my brake shoes on my 521 and now the driver side rear is getting HOT!!!! doesn't feel like its dragging really. I drive into town it seems fine and not hot but when I drive to work 20 miles by the time I get there is hot and can smell it. So I replaced the drums in the rear also and still does the same. I thought maybe it was the parking brake spreader that was jamming up. I released that and now its hot again at work. Im stumped for now.. Drum out of round?(made in China) But it happen with the orginal drum and now this one. I don't get it right now Edited September 10, 2019 by banzai510(hainz) 2 Quote Link to comment
]2eDeYe Posted September 10, 2019 Report Share Posted September 10, 2019 Did you change the wheel cylinder? Could be sticking. 2 Quote Link to comment
datzenmike Posted September 10, 2019 Report Share Posted September 10, 2019 Has to be rubbing to generate heat. Does tire spin freely? After pumping the brakes? Maybe leading and trailing shoes were reversed on both sides before. Now the left rears were put on correctly by accident and this wheel is doing more work than the other side? Leading shoes are different from trailing shoes and brake harder by servo action from wheel rotation. Maybe the other side has stopped working (for example wet shoes) and the left rear is doing all the work??? 3 Quote Link to comment
banzai510(hainz) Posted September 10, 2019 Author Report Share Posted September 10, 2019 (edited) all the brakes are warm when driving for awhile esp going down hill. Just that the driver side rear is getting Untouchable hot. as for leading and trailing shoe the parking brake has a hole for the Parking brake pivot so its really hard to mess this up. But what I remember its usually fits both sides. Most likely a CLONE of the other. as for the cylinder being sticky it wasn't happening till I swapped the brake shoes. Im just missing something simple but not catching it. Mike as you mentioned about the leading and trailing. I thought of this also . a old guy at work told me they used to conform the shoes to the drum. But in 2oyears of owning this I never had rear proplems with the brakes on a 521 before. Its getting HOT and worried of going to fuck up the seal. I had this happen on my Jeep where the drum is out of round and needed to be TURNED on the machine to get TRU round. But the drum releases fine when I have my girlfriend hit the brakes. Maybe I will swap drums and see if it moves to the right side. Edited September 10, 2019 by banzai510(hainz) 2 Quote Link to comment
]2eDeYe Posted September 10, 2019 Report Share Posted September 10, 2019 If it is releasing on the jackstand the cylinder is likely ok. Is the drag different between the 2 wheels? Swapping drums sounds like a good idea, if nothing else it eliminates the drum as the issue. 2 Quote Link to comment
banzai510(hainz) Posted September 10, 2019 Author Report Share Posted September 10, 2019 Yes it always spun around and releasing As with most drums they all drag just a little bit. as one adjust them. Im just pissed that all was fine then I had to change them thinking well its summer do this now before winter as the drums were getting on the thin side. 3 Quote Link to comment
DanielC Posted September 10, 2019 Report Share Posted September 10, 2019 Check to make sure the the adjuster slider (carrier) moves aft and forward with approximately the same force. Factory specification, the adjuster sliding resistance is 11 to 26 pounds of force to move it. 2 Quote Link to comment
banzai510(hainz) Posted September 10, 2019 Author Report Share Posted September 10, 2019 (edited) Daniel the sliding adjuster seems to be a little loose but it moves. I just showed the guys at work and it seems to work and they say the cylinder is good. so Im going home early to swap the shoes maybe that works but notice Daniel that the slider as you call it does moves more easily that the passenger side Edited September 10, 2019 by banzai510(hainz) 2 Quote Link to comment
banzai510(hainz) Posted September 11, 2019 Author Report Share Posted September 11, 2019 I swapped drums and tighten the lower slider and got hot again. turned the brakes fwd to rear and than loosen and drove about 6 miles didn't get hot but will wait and try out this weekend. Was hoping for people chime in on this 2 Quote Link to comment
datzenmike Posted September 11, 2019 Report Share Posted September 11, 2019 Shoe lining placement is important. Above you can see that the shoes are the same other than where the lining is bonded onto them. Note the lining is closer to the brake cylinder/adjuster at the top on the left shoe. This is correct positioning if the wheel is moving towards the left making the left shoe the leading and the shoe on the right the trailing. The shoe is even marked FORE so it is installed to the front. 3 Quote Link to comment
banzai510(hainz) Posted September 11, 2019 Author Report Share Posted September 11, 2019 thanks Mine said FF on both so I just swapped it and will see what happens. Mine was like you said above it slightly different bt no more than a 1/4 inch if that. Those drums its a lot MORE difference 2 Quote Link to comment
wayno Posted September 12, 2019 Report Share Posted September 12, 2019 When your changing out your brake shoes you have to release the e-brake completely from the center pull or at the very least loosen the adjustment as it is set/adjusted for the old brake shoes, when you put new brake shoes on that e-brake shoe can rub and get hot. Also you can get the drum on because the adjuster is not adjusted yet, once adjusted did you find it hard to remove the drum when you pulled it apart to see why it was getting hot and then have trouble getting it back on without loosening the adjuster? 2 Quote Link to comment
thisismatt Posted September 12, 2019 Report Share Posted September 12, 2019 Is it possible you have two of the fore shoes on one side and two of the aft shoes on the other side? 2 Quote Link to comment
datzenmike Posted September 12, 2019 Report Share Posted September 12, 2019 Indeed! If you don't notice the lining placement. You could replace by noting the original placement but this assumes the last guy did it right. If you reverse the leading and trailing shoes on both sides the vehicle, it will gave more grab backing up. I don't think all shoes are leading and trailing. I think I've seen sets where the lining is centrally located and all four are the same. 2 Quote Link to comment
banzai510(hainz) Posted September 12, 2019 Author Report Share Posted September 12, 2019 (edited) Matt. I don't know they were sealed plastic wrap in pairs and assume they are correct but maybe placed together wrong?. I will recheak this weekend. Just had jack truck up 15times and tired of doing it. Never had this happen before in 20yrs of ownership Wayno the ebrake cable broke years ago so there is no tension on there. the drums come right off as I antiseize the shit out of them now. so there is no dragging going on and off once I get them centered on. I also bleed it to release all tension from the cylinder. Edited September 12, 2019 by banzai510(hainz) 2 Quote Link to comment
banzai510(hainz) Posted September 13, 2019 Author Report Share Posted September 13, 2019 (edited) well they seem to work now. More or less I just swapped the shoes from front to back and put a old drum on. Since it works (this morning Im going to just leave it. I only need to get 4 or 5 more years out of this 521 then dump it Edited September 13, 2019 by banzai510(hainz) 3 Quote Link to comment
]2eDeYe Posted September 13, 2019 Report Share Posted September 13, 2019 You can dump that thing at my place when your done with it. :) 2 Quote Link to comment
datzenmike Posted September 13, 2019 Report Share Posted September 13, 2019 I said that back in the '70s. Took 8 years and it was still running. 521s are like zombies.... they run on an inexhaustible supply of evil. 2 Quote Link to comment
banzai510(hainz) Posted September 17, 2019 Author Report Share Posted September 17, 2019 well my brakes heated up last night again. the passenger one was hot and the right side was getting warm I adjusted the slop out of the front brakes and I think this might do it. Like Mike said maybe the rears were doing to much of the work. we will see. I should have adjusted it from the beginning 2 Quote Link to comment
datzenmike Posted September 17, 2019 Report Share Posted September 17, 2019 Well you could take out on a gravel road at 10MPH and jam the brakes on, get out and look at the marks. Might take several tries to get it right but they should all skid roughly equal. The 521 was a single master so weren't the wheel cylinder cylinder diameters engineered to provide the correct rear bias rather than a proportioning valve? The fronts should do the majority of the braking and the rears just compliment the fronts. The last thing you should have is the rears lock before the fronts. Once locked they can fish tail around. Never thought about adjusting the fronts, I assumed you were on top of that 2 Quote Link to comment
banzai510(hainz) Posted September 17, 2019 Author Report Share Posted September 17, 2019 I just backed the brakes off the adjusters thinking since they new I didn't need to. But the pedal still was half way down which was suspect. Now they at the top when I hit the brake 3 Quote Link to comment
banzai510(hainz) Posted September 18, 2019 Author Report Share Posted September 18, 2019 going to work they are fine coming home they still get warmish hot but not as much where I smell it 2 Quote Link to comment
Charlie69 Posted September 19, 2019 Report Share Posted September 19, 2019 Did you clean and lube the backing plates? Did you check the axle bearing for play? Pictures or it did not happen! LOL 1 Quote Link to comment
banzai510(hainz) Posted September 19, 2019 Author Report Share Posted September 19, 2019 well it was hot again last night. Where you lube the backing plates? Can a somewhat loose lower adjuster move around and cause this.????????????????? seems like going to work its not as hot but coming home it real HOT. going to work I have longer strectches where I don't use the brake. Coming home the last few mile I use the brake a lot and the rim is really warm. Guy at O rileys say its the wheel cylinder. I said it never happen until I put new brake shoes. I tool the drum in to get turn just by chance the drum is out of spec 2 Quote Link to comment
datzenmike Posted September 19, 2019 Report Share Posted September 19, 2019 The insides of the shoes rub against raised bumps in the backing plate. I think lithium grease will do or brake grease at least. Lithium won't melt and run down. Put a dab anywhere metal parts chafe and rub like the adjuster slide.. 2 Quote Link to comment
