Eriks Posted September 10, 2019 Report Share Posted September 10, 2019 Hi, anyone know a source for a 2 mm head gasket for a L20B ? Thanks. Quote Link to comment
datzenmike Posted September 10, 2019 Report Share Posted September 10, 2019 Nismo? The racing arm of Nissan? Two stock gaskets would be about 2.5mm when crushed. Quote Link to comment
Eriks Posted September 10, 2019 Author Report Share Posted September 10, 2019 Thanks. I have a L20B with flat top pistons and a 219 head. Noticed too late that the head had been milled 1 mm. Checked compression, it was 14:1. Not sure how much gasket I need to lower the compression to a ping free level. All advices are much appreciated. Quote Link to comment
datzenmike Posted September 10, 2019 Report Share Posted September 10, 2019 Roughly I get 12.89 but would need the combustion chamber to be cc's for it's volume. A second gasket adds only 6.8cc more volume to the combustion chamber. If my 12.89 is close then this drops it to 11.2. There's lots of room to remove material around the valves to unshroud them. This would open up the combustion chamber and lower the compression. You really would need to know what the combustion chamber volume is first with 1mm removed of the head. 2 Quote Link to comment
scooter Posted September 10, 2019 Report Share Posted September 10, 2019 kameari engine works Quote Link to comment
Stoffregen Motorsports Posted September 10, 2019 Report Share Posted September 10, 2019 HKS makes custom layered metal gaskets. I like them because they are reusable and you can adjust the compression by adding or removing layers. 1 Quote Link to comment
Stoffregen Motorsports Posted September 10, 2019 Report Share Posted September 10, 2019 2 hours ago, datzenmike said: Roughly I get 12.89 but would need the combustion chamber to be cc's for it's volume. A second gasket adds only 6.8cc more volume to the combustion chamber. If my 12.89 is close then this drops it to 11.2. There's lots of room to remove material around the valves to unshroud them. This would open up the combustion chamber and lower the compression. You really would need to know what the combustion chamber volume is first with 1mm removed of the head. Yes, this^^^^ Cut your chambers to match the bores, unshroud the valves, blend the bowls. You will lose compression this way, but in your case, this works in your favor. Quote Link to comment
Eriks Posted September 10, 2019 Author Report Share Posted September 10, 2019 (edited) I read somewhere that the original L20B bowl piston add 11cc, so that might be an option Edited September 10, 2019 by Eriks Quote Link to comment
