vic.rott Posted September 9, 2019 Report Share Posted September 9, 2019 Hello Ratsun members this is my first post, i have found many useful info here, and now i have a question about this engine, is a Mexican J16 in a 1981 720, i dont know what is this thing: I would apreciate all info. Thank you Quote Link to comment
datzenmike Posted September 9, 2019 Report Share Posted September 9, 2019 Looks like the hot water outlet from the engine to the hearer core inside the truck. The other hose returns the water to the lower rad return hose. Quote Link to comment
MikeRL411 Posted September 9, 2019 Report Share Posted September 9, 2019 Looks like the adapter I had to use to put an external block tank heater on the R1600 engine of my RL411 back in Montana. Quote Link to comment
vic.rott Posted September 9, 2019 Author Report Share Posted September 9, 2019 1 hour ago, datzenmike said: Looks like the hot water outlet from the engine to the hearer core inside the truck. The other hose returns the water to the lower rad return hose. Thanks, i was worried because there was water leaking, the other hose is disconnected and the heater core is not working Quote Link to comment
vic.rott Posted September 9, 2019 Author Report Share Posted September 9, 2019 1 hour ago, MikeRL411 said: Looks like the adapter I had to use to put an external block tank heater on the R1600 engine of my RL411 back in Montana. Maybe thats why the heater core doesnt work, is missing that external tank Quote Link to comment
datzenmike Posted September 10, 2019 Report Share Posted September 10, 2019 There's no external tank on the heater. Mikes talking about a block heater. It gets very cold in Montana. The heater on off linkage may have fallen off the valve and it's just closed closed all the time. It looks like, from here, that the hose clamps are really squishing the hose. They look very soft and may need replacing. You vacuum advance hose is also missing or fell off the distributor. Quote Link to comment
Stoffregen Motorsports Posted September 10, 2019 Report Share Posted September 10, 2019 The hoses don't look correct at all. Probably replaced at some point with something that kinda fit. The size is probably why they look squished. Quote Link to comment
vic.rott Posted September 11, 2019 Author Report Share Posted September 11, 2019 Thank you for all the info, the truck works well but it has a lot of work to do, i am going to start replacing those hoses and see what happens next. Thanks :) Quote Link to comment
